Front loader problem
/ Front loader problem #1
Kenelz
Lake City, Michigan
Deere
JD 790 with 419 loader. If try to feather the load up, it drops, pull a little farther on the control and it works as it should. Same going down, its like it's going in "float" mode.
Any suggestions?
Ken
/ Front loader problem #2
Been a registered member for 5 years and just now making first post?
I would check all the joystick linkages and check the spool bottoms (under the cups) for anything loose etc...
Good Luck...
/ Front loader problem #3
Dropping while trying to raise could be a load check in your control valve stuck open.
While lowering are you saying you get better control by moving the lever further Vs trying to feather?
like /pine states, check all the mechanical stuff first
/ Front loader problem #4
Have you had the hoses off lately?
Reads like you have the Lift & Lower hoses swapped.
:wrench:
/ Front loader problem #5
Like said before the load checks stuck open and it could be that it doesn't even have any. Show a picture of the valve.
/ Front loader problem #6
X3. Load checks.
What he is describing is exactly what a load check is for.
Thanks for the replies!
The load check sounds like a good possibility, is it hard to get to?
I miss posted, it only does it for raising the bucket.
I have had the hoses off, the loader is replaced with a front mount snowblower every winter. All the motions of the joystick are same as before, ie pulling back raises the loader.
Also, I put a shim pack in pump for more pressure, I removed them yesterday with no change for my problem.
/ Front loader problem #8
Depends on the style of the valve. If this is a stock JD part then the JD parts break down shows them being accessible from the same face as the work ports. I would suggest you look at the parts break down or talk to you local dealer. They should be able to verify where they are located.
/ Front loader problem #9
I believe this is the correct drawing for your valve (came from JDParts: Unsigned Landing Page its free, check it out). Luckily this is an older machine and shows the breakdown for it-the newer ones don't show anything but the valve itself.
SELECTIVE CONTROL VALVE
Cart key PART NO. PART NAME QTY SERIAL NO. REMARKS
1 M801517 Bolt 5
2 AM117917 Bracket 1
3 ...... Seal 2 (A)
4 ...... Washer 2 (A)
5 R51603 O-Ring 2 (A)
6 AM100201 Valve Kit 2 LOAD CHECK (INCLUDES R26448 O-RING)
7 ...... Housing 1
8 R51603 O-Ring 2 (A)
9 ...... Spool 1
10 AM117317 Kit 1 SPRING CENTER FLOAT
11 M114910 Screw 4
12 ...... Gasket 1 (A)
13 AM117327 Cap Kit 1 END CAP
14 AM117325 Kit 1 SPRING CENTER REGEN
15 ...... Spool 1 REGEN.
16 AM117366 Plug 1 (A), (SUB AM117916)
17 LVA802784 Selective Control Valve 1 NLA; ORDER LVA803422
LVA803422 Selective Control Valve 1
.. AM117916 Seal Kit 1 (INCLUDES PARTS MARKED (A))
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 1023E (A62177)
John Deere 1023E...
2016 International DuraStar 4300 Dump Truck (A61573)
2016 International...
2019 Caterpillar 349FL Hydraulic Excavator (A61572)
2019 Caterpillar...
2006 Chevrolet Silverado 2500HD Ext. Cab Knapheide Service Truck (A61573)
2006 Chevrolet...
