Loader front loader not full potential
/ front loader not full potential #2
A lot of good discussion on this subject on here. Just do a search!
Check fluid level
Check the screen if it has one
Check or change the filter
And
:welcome: to TBN! :thumbsup:
Happy :tractor: ing!
/ front loader not full potential #3
Check connections etc. for leaks.
/ front loader not full potential #4
Assuming we are talking about your L3400, another thing to check is the hydrualic suction hose. Early ones were a problem and prone to cracking. This would be about a 2" rubber hose just forward of your right foot when sitting on the tractor. If it is cracked, it could be sucking air.
Other than that and what has already been said, power is a function of pressure. And if it isnt an obvious problem, you need to get a hydraulic pressure guage and a quick coupler to test the loader ports.
/ front loader not full potential #5
ditto on LD1. you need to get a pressure guage and check the relief valves.
/ front loader not full potential #6
Put a hydraulic pressure guage on it and see if the relief is set too low. Kubota is frequently conservative when setting relief pressure. If you do a search, you should find plenty of reading on this.
2005 Dodge Caravan Van (A61574)
2005 Dodge Caravan...
2019 Kia Optima Sedan (A61574)
2019 Kia Optima...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
Informational Lot - Shipping (A63689)
Informational Lot...
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A64280)
UNUSED SDLANCH...
