Front Loader from a Ford Truck
   / Front Loader from a Ford Truck #121
Back in the 60s when I was growing up, Pa built a hay stacker from an old military truck. He took the body off and set it up to have the loader part over the rear, driving it backwards just like you are describing... It worked great and was set up to handle (8) 100lb bales. The baler had an "accumulator" on it that collected 8 bales (2 bales x 4 bales) and dropped them together. Then the homemade stacker would run around the field, picking up a set of 8 bales, then taking them to haystack and stacking them up to 12' high or so... BTW, Pa had degree in mechanical engineering so he figured all the loads and such out... he was very fast with the slide rule and could make most anything.
It is doable, I would not suggest renting it just due to the lawyers that chase everything.
I had a couple of neighbors growing up that did the same thing except it was for loose hay. Bucking and moving the hay piles at 20-30 mph versus tractor speed at the time. They used old trucks and put the loader on the back and reversed the transmission so that they would have at least four gears forward (towards the original rear end of the truck) and only one reverse. These machines were definitely fast and single purpose useful but would not compare with a regular tractor in mud or loading a feeder wagon or other chore type work. But out in a dry hayfield that you spent a month a year at least they saved a lot of time.
Not to mention they rode very smooth with the suspension as compared to a tractor and were a lot more run with the speed and rear wheel steer.
LOT: (2) Bucket Hand Pumps: (1) Gear Oil 1/2 Full, (1) Tranny Fluid 1/4 Full (A59076)
LOT: (2) Bucket...
NEW Fork Extensions (A59000)
NEW Fork...
2005 Sterling Acterra Tender Truck (A56435)
2005 Sterling...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2019 INTERNATIONAL...
