Front loader fit.
/ Front loader fit. #1
CelticKubota
I'm looking into buying a secondhand FEL. There's one available which came off a B22?? Kubota - Would this fit a B1750?. Its a Kubota Loader but has no numbers on it to help me identify its model.
Are Kubota loaders specific to each model or quite generic!
/ Front loader fit. #2
As far as the more recent loader models go, Kubota makes the loader to fit the tractor. I suspect they do this to make sure the tractor is not over loaded. When a loader picks up it cargo, the front axle takes the brunt of the force.
It's best to figure out what loader model goes with your tractor then hunt one down. I suspect numbers exist on the loader your looking at, maybe they are under the paint as a stamped set. Contact a dealer, they can usually help too.
/ Front loader fit. #3
Celtickubota
I'm assuming the loader you are looking at is either a LA211 (which came off a BX1800 or BX2200) or an LA210 (which came off a BX22). The B1750 is a larger compact tractor which would have used a B1640 kubota loader. The BX series loader won't fit your B1750 tractor. Quite often, with older tractors, we use Bush Hog loaders since they manifacture mounting kits to fit those older tractors. Hope this helps.
Lewis
/ Front loader fit. #4
Could it be off a Yanmar B22? Kubota didn't make a B22, Kubota makes a B21 but that has an integrated loader.
/ Front loader fit. #5
I think he is talking an older model Kubota 2250 which may or may not fit a 1750. It may be a little large for it???
UNUSED WOLVERINE HYD MINI AUGER (A64281)
UNUSED WOLVERINE...
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
Honda EM6500SX Generator (A62613)
Honda EM6500SX...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
