Front Hyd. Pump for Tractor
/ Front Hyd. Pump for Tractor #11
I don't know for sure the GPM. flow rate. It's small and the only thing you can clearly read is Vickers vane pump. The numbers I can see and searching 8 GPM..
/ Front Hyd. Pump for Tractor #12
The Ford 7710 I had used a PTO mounted pump, had a 25 gallon auxiliary tank, and ran a 4 foot cutter along with all the hydraulics it took to run the rear boom that was configured just like an extending backhoe arm. Rear PTO pumps can deliver a LOT of gallons per minute.
I also realize that the O/P is looking for a front mounted PTO pump, but as was brought up by others, a tank is also needed to cool the fluid. That may require an auxiliary tank mounted on the rear, which means it will act as a counterweight also. Putting the PTO pump back there will save just a little bit in mounting trouble and hose length.
David from jax
Brillam Water Tank (A59230)
Brillam Water Tank...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
Ryan Greensaire 24 Walk Behind Aerator (A59228)
Ryan Greensaire 24...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
