Front Hitch Reciever on 2720
   / Front Hitch Reciever on 2720 #1
trackid
NE.WI
jd2720
IMG_1749.jpgIMG_1747.jpg Needed a way to be able to move my trailer when I had my cutter on back so I added a receiver to the front of my 2720.
   / Front Hitch Reciever on 2720 #2
I made one out of 4 x 1/4 inch angle iron for my BIL. Just be careful about where the wink link is. My BIL bent the angle and tweaked the frame a small bit with too big of a camper trailer he was trying to park.
   / Front Hitch Reciever on 2720 #3
How large of a trailer is being moved? The thought of a front hitch receiver is perfect! I have a fairly heavy (don't know weight) three horse twin axle trailer that gets moved once in a while and grabbing my 2720 which Is parked right next to it sounds like a way better solution than getting the 1T 4 door 4x4 doully, warming it up and then trying to get it lined up.
   / Front Hitch Reciever on 2720 #4
I'm not really sure but I think it is in the 24 to 28 range. I know it won't go through a 10' tall door because of the roof air conditioner.
   / Front Hitch Reciever on 2720 #5
Holly schamolly. That is a bigun for sure. Does the tongue have a wheel on the jack so it is just a push? Or is the jack lifted and the tractor has to "carry" the weight?
   / Front Hitch Reciever on 2720 #6
Oh and did you buy the setup, or have it fabricated?
   / Front Hitch Reciever on 2720 #7
I didn't see it happen but the jack was probably up.
I made it for a smaller camper he had and it worked great for many years, untill he traded it for the big one.
   / Front Hitch Reciever on 2720 #8
Did you buy the receiver assembly or make it? It looks very hand. Thanks Bigtiller
I built this hitch. Trailer is my landscape trailer, used to haul the tractor. It weighs about 2000#. The flat stock attached to the frame is 3/8". I purchased the square blank from the local fleet farm. IMG_1754.jpg Back of receiver is attached under it to a flat piece bolted to the grill guard bolts.
Jeep Front & Rear Differential (A50121)
Jeep Front & Rear...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
2005 Chevrolet Uplander Van (A51694)
2005 Chevrolet...
Trailer w/ 500 Gal Tank & Pump (A50121)
Trailer w/ 500 Gal...
