Front Hitch Reciever on 2720
   / Front Hitch Reciever on 2720 #1
trackid
NE.WI
jd2720
IMG_1749.jpgIMG_1747.jpg Needed a way to be able to move my trailer when I had my cutter on back so I added a receiver to the front of my 2720.
   / Front Hitch Reciever on 2720 #2
I made one out of 4 x 1/4 inch angle iron for my BIL. Just be careful about where the wink link is. My BIL bent the angle and tweaked the frame a small bit with too big of a camper trailer he was trying to park.
   / Front Hitch Reciever on 2720 #3
How large of a trailer is being moved? The thought of a front hitch receiver is perfect! I have a fairly heavy (don't know weight) three horse twin axle trailer that gets moved once in a while and grabbing my 2720 which Is parked right next to it sounds like a way better solution than getting the 1T 4 door 4x4 doully, warming it up and then trying to get it lined up.
   / Front Hitch Reciever on 2720 #4
I'm not really sure but I think it is in the 24 to 28 range. I know it won't go through a 10' tall door because of the roof air conditioner.
   / Front Hitch Reciever on 2720 #5
Holly schamolly. That is a bigun for sure. Does the tongue have a wheel on the jack so it is just a push? Or is the jack lifted and the tractor has to "carry" the weight?
   / Front Hitch Reciever on 2720 #6
Oh and did you buy the setup, or have it fabricated?
   / Front Hitch Reciever on 2720 #7
I didn't see it happen but the jack was probably up.
I made it for a smaller camper he had and it worked great for many years, untill he traded it for the big one.
   / Front Hitch Reciever on 2720 #8
Did you buy the receiver assembly or make it? It looks very hand. Thanks Bigtiller
I built this hitch. Trailer is my landscape trailer, used to haul the tractor. It weighs about 2000#. The flat stock attached to the frame is 3/8". I purchased the square blank from the local fleet farm. IMG_1754.jpg Back of receiver is attached under it to a flat piece bolted to the grill guard bolts.
2015 JLG 6042 Telehandler (RIDE AND DRIVE) (A50774)
2015 JLG 6042...
1989 Freightliner Cabover FLA086 (A52748)
1989 Freightliner...
2020 International MV607 2,000 Gallon Water Truck (A50323)
2020 International...
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
John Deere 4045D (A50121)
John Deere 4045D...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
