Front end went clunk
/ Front end went clunk #1
philbuilt
Maine
1260 Massey/retired. Mahindra 2555 cab TLB
Again pushing snow again, not much load. I dumped the bucket and started to back up and the front axle went clunk. /forums/images/graemlins/mad.gif So I took it out of 4whd and the left tire locked up. So its in the shop and I took the left front assemble off . I found the gear on the axle shaft has chips in it. Any ideas what caused this? I can take some pics if needed. 1260 mf with 186hrs
thanks
phil /forums/images/graemlins/mad.gif
Sorry But, I have another question. Is the a parts breakdown online that I can look at?
Phil
Ok I went to the dealer and bought the service book.
Took the axle apart and the pinon gear was wiped clean ring has damaged teeth. PT# 3703258m92 8x32 not interchangeable with 3703258m91 Hope to order parts in the AM. Is there someplace on the west coast still open? Parts will have to be shiped anyway. 1/31/06 7:14 eastern time
Phil
/ Front end went clunk #4
Wow. That is the first that I have heard of on a the larger 1200 series. Have you tried Jack's Small Engines . The people that I have spoken with that have ordered from them have been pleased. They are usually less expensive that most dealers. Since you have the part number, you can go to the above page and it will give you the price.
Thanks for the info I followed the url and Jack did not stock parts. I ordered them this morning and they will be here friday.
Thanks
Phil /forums/images/graemlins/laugh.gif
/ Front end went clunk #6
Ok? What does he do? Order after you place your order.
Sorry, I ordered them from my local dealer.
/forums/images/graemlins/laugh.gif All parts are in and the 1260 is moving again /forums/images/graemlins/grin.gif
Thanks for the help
Phil
/ Front end went clunk #9
Hi Phil,
Glad to hear that you got your parts and are up and running again /forums/images/graemlins/grin.gif Just curious, did anyone speculate why you had that type of failure with such low hours??? It doesnt sound right to me, and just wondering.
scotty
No not really, I did note several theads back about the back tire chattering. So we checked the tire air pressure and it was off. Here is my conclusion Front tire pressure left and right had a differance of 26lbs. now they are even with the tire inflated to the higher pressure it was approximately .75" taller. I also noted when I dissasembled the front axle I only drained approximately 3 qts of oil. Book calls for 6.4 qts.
So the moral to the story is. When you buy a used tractor (little hour or not) Drain and change all fluids. I did all filters and motor oil days after that I bought it. I grease it every 20 hrs. The book said to change the front axle at 300 hrs. So I did not check it. My Bad /forums/images/graemlins/mad.gif
It running good and I love the seat time /forums/images/graemlins/grin.gif
Thank Phil
I will post part pix soon It's a sad sight " SO CHECK YOUR FLUIDS"
http://www.tractorbynet.com/photos/showphoto.php/photo/2740 /forums/images/graemlins/crazy.gif
/ Front end went clunk #11
Mornin Phil,
Thanks for the reply. On my MF 1040 I drained both front reduction units and also the front pinion housing, yeah three different gear lube resevoirs, just in the front housing. One front reduction unit had a mix of water and gear lube /forums/images/graemlins/frown.gif The previous owner left the machine outside most of the time /forums/images/graemlins/frown.gif Im happy to have a barn to keep the tractor in now, even if it isnt mine /forums/images/graemlins/laugh.gif Glad to hear your up and running!
scotty
/ Front end went clunk #12
Was it like an automotive differential where you have to adjust the gear contact by adding/subtracting shims when replacing ring and/or pinion?
Anyway, I'm glad you're up and running and hope you have the problem solved for good, where it's not a case of something more subtle like a component being bent or out of adjustment that caused the failure.
Yes it is very much like a rear axle. You do adjust the end play with shims. The biggest differance is the crush nut you adjust the tension on the 2 internal bearings 5 inch pds. or 11 to 13lbs at rotation startup. Twist a string around the end of the shaft and use a small scale. Then pull mine is set at 12.
/forums/images/graemlins/smile.gif It snowed and the seat time was mighty fine /forums/images/graemlins/grin.gif
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
Hedge Posts (A65640)
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
LOOK! (A63111)
LOOK! (A63111)
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
