Front end vibration
/ Front end vibration #11
Hey Reg, is this a Branson only problem? I have 800 hours on my Century and no loose tie rods... I thought they are identical tractors with different loaders. Maybe I'm just lucky? I do torque all the loader bolts at normal service time but have never thought to check the pinned ones. Checked them after I saw your post and their tight.
Jesse
/ Front end vibration #12
Jesse
As I understand it Century/Branson/Kukje all the same and IF it is more than (I think) 3 years old it is LIKELY to have the smaller tie rod ends.
If you keep them tight I don't think you will have a problem.
Again, as explained to me the BREAK due to waisting wear from being loose.
Two slight differences between Cs and Bs.
The front tires if R4s were wider on Cs, though I don't remember by how much.
Yes, there were different loaders offered; BL20A on Bs and C50 HL on Cs.
Supposedly the C50HL has a higher capacity and "better" sub frame - if true that might explain the use of higher rated front tires for loader work (IMO, etc)
Ahh, thanks for the reminder; I just remembered that I got split washers for mine and after that couldn't get the cotter pin in, so my tightness is dependent on those split washers.
Have a few hours on it since, so ....reminder, reminder, I should get out there and check.
2006 Godwin GHP45KW-RC45kW Towable Generator (A59228)
2006 Godwin...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
