Front end loader vs another tractor
/ Front end loader vs another tractor #1
deerefan
louisiana
1952 8N, 2005 JD 5103
After finding out the loader for my 5103 costs roughly 4500, I started comtemplating finding a smaller tractor w/ a loader for the same price. Granted, it won't have the lift capacity of the 5103, but I don't lift real heavy stuff any way. The tractor also has more than one use vs a loader. I was looking at some off brand name tractors from 20-30 hp. I know of Yanmar, are there other tractor brands out there that sell these reconditioned tractors fairly cheap? Do you think I would be better off in the long run just putting the loader on mine and forget about the other tractor? Just looking for some input...hard decision!
/ Front end loader vs another tractor #2
If you have use for a larger machine, look into a used Ag tractor/loader. Lots of power and weight per dollar compared to the compact market. My little 16 hp Kubota with loader that lifts only 500 lb is worth about $4500 on trade, a bit more if I sell it outright.
/ Front end loader vs another tractor #3
I would go ahead and just get the loader for your 5103. I think in the long run, another tractor would cost you more money anyway.
/ Front end loader vs another tractor #4
IMHO go for the loader for your 5103. Don't know how used tractor sales are in your area but where I live finding used small tractors with a loader in the 4500 range are far and few between. I looked for almost 2 years for a used tractor w/ loader and found used ones here were selling only a few grand less than new so I bought new. If you can find a good smaller tractor w/ loader in your range then go for it.
/ Front end loader vs another tractor #5
Get the loader for your 5103; if you spend the $$ on a smaller tractor you'll kick yourself every time you want to move something that's too heavy. Until you get the FEL and have it available to you 24/7 you just don't realize how much you'll use it.
/ Front end loader vs another tractor #6
Consider how hard or easy it is to take the loader off and how much you need to use the tractor without the loader too. The things make the tractor a lot more cumbersome to use when they're just hanging out in front being nothing more than weight.
/ Front end loader vs another tractor #7
I would buy another tractor. A TLB to be exact.
But my loader needs would require a smaller tractor.
It really depends on exactly what else you need the tractor/loader for.
KO
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
FLUID PUMP (A67714)
FLUID PUMP (A67714)
Shop Cart (A68134)
Shop Cart (A68134)
2014 PETERBILT 389 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A68363)
2014 PETERBILT 389...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A66736)
2013 Chevrolet...
