Front End Loader Problem
/ Front End Loader Problem #1
Al Crandall
New Holland T4.75
Have a New Holland t4.75 with a 655 tl front end loader, handle that started getting hard to push side to side to tilt bucket, the next day lever was hard to push to raise and lower lift, checked Hydro fluid and it was good, thanks for any help.
/ Front End Loader Problem #2
Are there cables from the joystick to loader valve? If so, I would start with the cables.
Thanks, I'll check it out.
/ Front End Loader Problem #4
If your joystick has cables and further if it has a lock on the joystick to prevent inadvertent loader movement when on the road, start by locking the joystick.
The cable ends will connect to the loader valve spools with pins. Remove the pins so the spools can be centered without cable influence.
Now adjust the outer cable at the loader valve until the holes in the cable ends line up with the holes in the valve spools. Then reinstall the pins.
When the pins connecting the joystick cable are removed, unlock the joystick and check for easy smooth joystick movement.
Re-lock the joystick if cable movement is smooth and center as noted above.
Dave M7040
Thanks guys, I love this forum.
New - Front mount rototiller
New - Front mount...
BUNDLE OF (3) 2" X 20' (3) 1 1/2" X 20' (3) 1" X 2 (A64281)
BUNDLE OF (3) 2" X...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
UNUSED WOLVERINE HYD ADJUSTABLE BALE SQUEEZE (A64281)
UNUSED WOLVERINE...
2012 Ford Expedition SUV (A61574)
2012 Ford...
2008 Toro Multi Pro 1200 Turf Sprayer (A61572)
2008 Toro Multi...
