Front End Loader Leveling Arms?
   / Front End Loader Leveling Arms? #31
In the system the relief dumps the fluid from the from the tilt circuit back to the lift circuit so the the cylinders either extend or retract accordingly. With out the relief in the system, everything locks up. The linkages and cylinders continue be pushed as the lift cylinders continue to move. Something has to give at some point. When something gives... it's scary. I have seen one practically explode due to a malfunctioning relief.
Do you really know what you are talking about, the operation of the leveling
system has been explained, operaters who have had some experience with
FELs will avoid the danger areas, the main two being , lifting the bucket
while it is the fully dumped position or lowering it
with the bucket fully retracted. On any loader I have used one or both these
situations were best avoided.
   / Front End Loader Leveling Arms? #32
Rback33, has KMW changed the hydraulic leveling package that I have on my Mahindra 7520 tractor? Or are you guys using the same valve on all of your loaders that have the self leveling option? Have you come up with an on-off switch for them like Kubota has. I sure wish that mine had an on-off capability. There are many situations that I would prefer to not have the self leveling feature.
   / Front End Loader Leveling Arms? #33
Do some searching. The answer is easy to find.:)
It has evolved a great deal, but it is still the same basic design. It cannot be turned off and on. The only thing you can do is un-plumb it and re-plumb as needed. It only takes a few minutes to do. ;)
   / Front End Loader Leveling Arms? #34
No need.
Just do the geometry right and the cylinders don't "fight each other".
Kioti KL451 and similar are examples of this.
If Kioti dealers aren't plentiful in your area take a look at a John Deere CX400 loader, which I just happened to see at a horse show today.
Now THAT is an easy one to understand, without even seeing it go up and down (-:
Heck, their brochure probably shows it and even a picture should be enough.
I don't need the Kioti dealer.... We designed their first MSL loader. And the second and the third....:D
   / Front End Loader Leveling Arms? #36
rback,
I wish you guys would have built a KMW version of the Kioti KL120/130's FEL's. Kioti would have been much farther ahead.
Don
That makes two of us Don! We have talked about going ahead and quoting it, but they have never sent us a tractor. The person who was pushing it passed away recently so I doubt we ever get the chance.
   / Front End Loader Leveling Arms? #37
Who, which "We" ?
Are YOU a principle designer there ?
   / Front End Loader Leveling Arms? #38
I have one on my New Hollland TN75D and while it is great for fork work, it severely limits bucket rollback for bucket work, ie: loading materials. That's why usually for straught bucket work I'll use a tractor without it.
Andy
   / Front End Loader Leveling Arms? #39
Not really practical to plumb and un-plumb it several times a day, or sometimes even minutes apart. I hope that the new one has improvements in it, because I know that I would not purchase it again if it was the same as mine.
   / Front End Loader Leveling Arms? #40
I found a picture of my loader, with the most basic (and most true) form of parallel linkage:
You can see the blue and purple lines i drew, connecting the linkage pins of the main boom and the parallel links.
i got lost in all the hydraulic mumble jumbo.
from the pic posted in that quoted post, (and from what ive seen in person) there is no way to bind a properly designed mechanical parallel arm system.
leave all the hydraulic bypass BS out of it. K.I.S.S.
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2000 JLG 800A TELESCOPIC/SCISSOR BOOM LIFT (A52709)
2000 JLG 800A...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
2008 TEREX TRAILER LIGHT TOWER (A58214)
2008 TEREX TRAILER...
2008 WABASH 53FT REEFER TRAILER (A58017)
2008 WABASH 53FT...
2006 Intellistrobe Automatic Flagger Assistance Device S/A Towabale Trailer (A55973)
2006 Intellistrobe...
