Front End Loader is Sticking
/ Front End Loader is Sticking #1
jrepp44
NW Louisiana
Kubota B2650HSTC
When i raise or lower the FEL with the joystick and then release the joystick the joystick returns to center but sometimes the FEL will continue to raise or lower. I have oiled the joystick, what else should I look for? Kubota L5030 HSTC / LA853 loader with 2000 hours of heavy loader work. Thanks, Jim
/ Front End Loader is Sticking #2
If your joystick has control cables that lead to the actual hydraulic valve, the cable could have become corroded and does not allow the hydraulic valve to return to center. This can be as simple as lubricating the cable.
If the joystick is directly connected to the hydraulic valve, look for anything that might prevent the valve from centering.
Lou Braun
generator trailer (A61569)
generator trailer...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
2022 EZ-GO ELITE...
2015 Ford Taurus AWD Sedan (A61574)
2015 Ford Taurus...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2002 International 9200i Truck (A61307)
2002 International...
