Front End Loader is Sticking
/ Front End Loader is Sticking #1
jrepp44
Bronze Member
NW Louisiana
Kubota B2650HSTC
When i raise or lower the FEL with the joystick and then release the joystick the joystick returns to center but sometimes the FEL will continue to raise or lower. I have oiled the joystick, what else should I look for? Kubota L5030 HSTC / LA853 loader with 2000 hours of heavy loader work. Thanks, Jim
/ Front End Loader is Sticking #2
If your joystick has control cables that lead to the actual hydraulic valve, the cable could have become corroded and does not allow the hydraulic valve to return to center. This can be as simple as lubricating the cable.
If the joystick is directly connected to the hydraulic valve, look for anything that might prevent the valve from centering.
Lou Braun
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
JOHN DEERE 5075E TRACTOR (A63291)
JOHN DEERE 5075E...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
