Front End Loader, Du-AL
/ Front End Loader, Du-AL #1
MikeGB
Hello guys, I have an rather old front end loader I use on my Kubota L2250 and both of the tilt cylinders are leaking oil. I need to get them both rebuilt. My FEL is a model 105 made by Du-AL. I understand that Woods bought them out a long time ago. Has anyone on here rebuilt their tilt cylinders on their Du-AL FEL? I'm looking for the correct seal kit to rebuild the cylinders. I know there has to be millions of kits out there and I just want to be sure I get the right kit. Thanks Mike
/ Front End Loader, Du-AL #2
Friend of mine has that same loader on his 1986 L2850, and has replaced one curl cylinder, not sure if the other was repacked or not. I will be talking to him tomorrow, will try to remember to ask him about it.
/ Front End Loader, Du-AL #3
Try a Woods dealer. They may carry the parts or be able to get them. Another possibility is a hydraulic shop. You generally need to know the correct piston diameter, cylinder ID, and the correct rod diameter.
/ Front End Loader, Du-AL #4
X2 what Jerry says.
If we knew where you were we might be able to suggest a reputable hydraulic shop.
