Front End Loader, Du-AL
/ Front End Loader, Du-AL #1
MikeGB
Hello guys, I have an rather old front end loader I use on my Kubota L2250 and both of the tilt cylinders are leaking oil. I need to get them both rebuilt. My FEL is a model 105 made by Du-AL. I understand that Woods bought them out a long time ago. Has anyone on here rebuilt their tilt cylinders on their Du-AL FEL? I'm looking for the correct seal kit to rebuild the cylinders. I know there has to be millions of kits out there and I just want to be sure I get the right kit. Thanks Mike
/ Front End Loader, Du-AL #2
Friend of mine has that same loader on his 1986 L2850, and has replaced one curl cylinder, not sure if the other was repacked or not. I will be talking to him tomorrow, will try to remember to ask him about it.
/ Front End Loader, Du-AL #3
Try a Woods dealer. They may carry the parts or be able to get them. Another possibility is a hydraulic shop. You generally need to know the correct piston diameter, cylinder ID, and the correct rod diameter.
/ Front End Loader, Du-AL #4
X2 what Jerry says.
If we knew where you were we might be able to suggest a reputable hydraulic shop.
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
2012 JOHN DEERE 210G LC EXCAVATOR (A65053)
2012 JOHN DEERE...
JOHN DEERE 702 - 8 WHEEL V-RAKE (A64278)
JOHN DEERE 702 - 8...
UNVERFERTH 6R36" RIPPER / STRIPPER (A64278)
UNVERFERTH 6R36"...
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A64556)
2023 26ft Freedom...
