Front End Loader 1963 Ford 4000
/ Front End Loader 1963 Ford 4000 #1
HardlyAble
Ford 4000
Help, I recently replaced the pressure and return hydraulic lines going to the right lift arm ram (they were leaking). Now the bucket lifts unevenly. The bucket tilt function is good and strong, it was all working fine till the hoses popped, no reason to think anything got bent. The bucket lift feels good and strong too, just uneven, meaning the right arm lags behind the left. Any suggestion? And thanks.
/ Front End Loader 1963 Ford 4000 #2
Were the hoses you used for replacement the same inside diameter as the old ones? They could allow more (or less) flow on one side than the other. You may need to replace your other old hoses to achieve equality.
/ Front End Loader 1963 Ford 4000 #3
"......fine till the hoses popped......." Explain.
/ Front End Loader 1963 Ford 4000 #4
If the hoses popped, then the piston seals may have failed in one cylinder causing it to lift unevenly.
AUCTION STARTS HERE @ 9AM (A63276)
AUCTION STARTS...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
Kobelco SK55SRX Excavator (A65579)
Kobelco SK55SRX...
Conveyor (A64194)
Conveyor (A64194)
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
