Front end help
/ Front end help #1
robbyr
Elite Member
western east central texas
ford and mahindra
This happened today. I think the part in my hand is the arm steering knuckle. How do I remove the part from there to hub. Do you beat it out like a ball joint? Don't wanna tear anything up. IMG_5380.JPGIMG_5383.JPG
/ Front end help #2
You should be able to drive it out. I have hammered down on the hub with success. What caused it to break?
/ Front end help #3
I'm seeing a seal that is right at the break. You will need to remove the seal and inspect what is below that. I'm guessing it's a snap ring- which would be hard to see with all the grease. Something has to hold that in if the front wheel is unweighted.
*as stated above- this is a guess based on my experiences
/ Front end help
Not really sure. It's been screeching some but I couldn't figure out where it was coming from. Greased it all up real good. Moved a trailer with ball mounted on bucket and noticed it broke when headed back to house.
/ Front end help #5
I sure hate that happen to you. The sector shaft on my Kioti snap just like that. Kioti wanted $650 and the part was not available. They suggested I by a new power steering unit for $3800. I bought a sector shaft for a Kabota that fit and worked perfectly. It seems like the quality of steel used these days is not near as good as it was back on the farm. I don't remember ever having failures like this.
/ Front end help
Didn't know Kubota parts would fit a Kioti. Truth be told I'd never heard of Kioti til I got on TBN.
/ Front end help #7
Kabota said it wouldn't work as well. But it was worth the $230 to find out. It fit perfectly with no modifications. That was about 2 years ago and haven't had a problem since. Sometimes you get lucky. Lol
2013 Ford Taurus Sedan (A61574)
2013 Ford Taurus...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
2022 John Deere 7R 210 Tractor (A63111)
2022 John Deere 7R...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2004 International 8600 Tender Truck (A63688)
2004 International...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
