Front end coming up while plowing snow with FEL mounted snow plow
   / Front end coming up while plowing snow with FEL mounted snow plow #31
With a snow blade, the only way to go is with a chain so the blade only floats. An exception is if some more down pressure is needed for packed snow.
If down pressure is needed put a piece of pipe over the chain.
   / Front end coming up while plowing snow with FEL mounted snow plow #32
When I designed the mount for the blade on the Kubota, the QA plate can be dumped into the plow frame hard enough to lift the front of the tractor if necessary.
   / Front end coming up while plowing snow with FEL mounted snow plow #33
Yea I was here a week ago and couldn't get any real answers in how to plow my property in float and not have the tractor jackknife up. Couldn't be simpler and works splendidly View attachment 1962552View attachment 1962553
I can't tell you how much I appreciated your post Mike! I recently put a Kubota front end loader mounted snowplow on my B2301, and attached a 1 1/2" pipe to the cutting edge of the plow, however whenever I left the plow in float, it would dig in and lift the front end of my tractor just as you described. I purchased the spacers and then noticed that you put a collar on the shaft so the spacers wouldn't get jammed...smart move! I have the collars on order and can't wait to try out this setup...it makes perfect sense! Here's a couple pics of my plow with the pipe attached.
2020 DRAGON ESP...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2020 Ford F-150 4X4 Ext. Cab Pickup Truck (A55973)
2020 Ford F-150...
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
toro reel master (A56857)
toro reel master...
