Oil & Fuel Front Diff Oil
/ Front Diff Oil #1
jlsanborn
Spokane, WA
Kioti CK20S Gear
Dealer performed my 50hr out of courtesy, less the front axle. When he was here delivering my tractor I asked what to put in there and he said tractor hydraulic oil. I recently got my owner's manual which says gear oil (which I would have guessed). What are the rest of you putting in there?
/ Front Diff Oil #2
The new oil was hydraulic fluid. I was advised to replace it with 90 weight gear oil at the 50 hours service. So, that's what's in it. So far so good, about 450 hours, second 90 weight change out.
Search here. It's been discuss a bunch. Make sure you get it full.
/ Front Diff Oil #4
I would think tractor hydraulic oil would be too thin. I would stick with the 90w gear oil.
/ Front Diff Oil #5
My manuals call for UTF, I guess if it is good enough for the tranny and rear it should work in the front differential.
/ Front Diff Oil #6
80w-90 gear oil. Recheck your oil level after moving the tractor a few hundred yards.
/ Front Diff Oil
Gear oil it is! Thanks all.
/ Front Diff Oil #8
UTH is typically in the 30 weight range, 80w-90 is in the 40 weight range. The additives would matter more and the 40C viscosity. Normal use will not generate enough heat to reach the higher 100C viscosity.
40C = 104F
100C = 212F
/ Front Diff Oil #9
Gear oil with the EP, (extreme pressure), designation offers the highest level of protection. This is also available in a synthetic formulas for a reasonable price.
But, good hydraulic oil also works. That's why the factories are using it.
/ Front Diff Oil #10
Up here, we use Shell Donax Hydraulic Fluid. There are several small cavities for the front axle fluid to move through. The lighter hydraulic fluid seems to perform better in the colder climates. It doesn't get the benefit of warm-up from the tractor.
/ Front Diff Oil #11
That's what I like about the synthetic gear oil.
/ Front Diff Oil #12
I just changed the front axle lube in my new-to-me 2004 Kubota B21. I'm in a cold climate & a big fan of synthetic - I use it in everthing that is run in the cold.
The local Kubota dealer carries Tutela 75W-90 gear lube so that's what I used.
/ Front Diff Oil #13
I use the Shell Donax TD hydro oil for the main part of the tractor. It's a 10w-30 weight oil that seems a little thin for the front axle. The 80w-90 I put in the front axle was synthetic and not overall expensive being that you don't need that much. Just my thought but I can see MIE's point if there are small cavaties for the oil to get to. Maybe that's why I had to check and add oil to my front axle twice after the refill.
/ Front Diff Oil #14
I used 90w gear oil at 50hrs and haven't changed it since. I cannot imagine it makes much difference so long as it is slippery fluid. It's not like these tractors are flying around at 60mph or that the front diff is a precision high pressure pump like the HST. Pretty big gears moving pretty slowly so why wouldn't just about any oil work? When I spill 90w oil it certainly gets into very small cavities. I can see the potential benefit of hydraulic fluid in very cold weather though.
/ Front Diff Oil
I'll go with an EP 90w I suppose. I'd agree with IT in that we're talking low speeds here. Once all the tiny spots are full I can't imagine a need for volumes of lube moving from here to there in any hurry.
Bucket (A64194)
Bucket (A64194)
L6060 Kubota For Sale
2016 Ford F-250 Knapheide Service Truck (A64194)
2016 Ford F-250...
Landhonor Skid Steer 3Pt Hitch Adapter (A62679)
Landhonor Skid...
(15) IH Suitcase Weights (A66408)
(15) IH Suitcase...
2012 CASE CX350C EXCAVATOR (A65053)
2012 CASE CX350C...
