Snowblower Front Blower For Compacts
   / Front Blower For Compacts #11
The narrow impeller for the blower
is an issue with the open auger design as
the open auger essentially defeats the
speed of the impeller as the amount of
snow removed is only as much as the
narrow paddles of the impeller allow
at any revolution.
It seems counter productive really where it
shreds the snow and has a very low
tonnage per hour due to the small transverse
impeller.
   / Front Blower For Compacts #12
Curiosity got the best of me and I gave these folks a call. To provide oil for their pump they said, "some sort of T needs to be put in a line to pull the oil from the hydrostatic sump and a connection made to return the filtered oil to the sump." Apparently you get to figure the details of that out yourself. He said where they live, 0dF and below.. no worries about heating the oil too much, but in warmer climates, upper 20's, it could be an issue. Price without shipping, 60" blower with rear PTO mounted pump- $8350.00, 60" blower with mid-PTO pump, $7750.00. I can hire my neighbor to plow me out for a long time for that kind of money.
   / Front Blower For Compacts #13
"OR buy a front mount 3 point hitch kit from pronovost to use the rear blower up front."
Not a Hyd guy but??? Could'nt one jsut fab a tank and use a pump of the PTO make this work. Or do youjsu use one of the rear Hyd connections for the access and hols it open?
Seem there is a better mosue trap somewhere here. I would love ot be abel to lift the blower to about 6 feet high. I could shave banks back for intersections.
   / Front Blower For Compacts #15
I think that would be easiest rather than tapping into existing system.
I thought about that too, but that means the tractors pump is supplying the flow and pressure. The specs call for 14-16gpm, how many compact tractors have that much flow? He also gave me the impression that it runs higher than the normal 2000-2500psi but he didn't say for sure.
Seem there is a better mouse trap somewhere here. I would love to be able to lift the blower to about 6 feet high. I could shave banks back for intersections.
They make PTO pump and tanks, if you HAD to have the height, I would go seperate tank rather than use the tractors supply.
I can add a mid-PTO for my tractor and front mounted 60" snowblower for less than $4K, but I couldn't get the height that this one will give you and for me... I don't have the need for the height.
   / Front Blower For Compacts #16
If a tractor already has a 10+ gallon hydraulic reservoir with built-in cooling capacity, it's attractive to make more use of it. But connecting into it means finding a big enough port. I don't think the atmospheric suction filter pipe on most tractors will deliver enough flow. On the bigger HST's the suction tube to the charge pump might be bigger - but what about its filter? Anyway, it's not something the average customer wants to tear into. The hydraulic tie-in will need model-by-model installation support.
Maybe there's more to know here. They've put serious thought and development into the product line so far. I'd like to learn more about the two concentric auger/impeller drives. The side-delivery walkway model looks interesting too.
Happy New Year TBN-ers! Dick B
   / Front Blower For Compacts #17
Thanks for looking into it Jim. ...But SHEESH! That's pricey!! As I understand it, you can get an Erskine front mount blower with a PTO mounted pump and reservoir for no more than that, and that's a lot more equipment included and no risk of messing up your tractor's hydraulics, nor having to hobcobble some "tap" into the system. I think they had a good idea but perhaps missed on the execution.
   / Front Blower For Compacts #18
I like it but the cost is pretty steep for my wallet even at half price.
Al
TAKEUCHI TL12V2 SKID STEER (A51242)
TAKEUCHI TL12V2...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2017 Nissan Rogue SUV (A50324)
2017 Nissan Rogue...
2013 Ford F-150 XLT - EcoBoost, Blown Engine, Good Parts Truck (A51039)
2013 Ford F-150...
UNUSED INDUSTRIAS AMERICA C18 CATTLE LOADING RAMP (A51243)
UNUSED INDUSTRIAS...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
