Front Blade
/ Front Blade #1
Maibox
Winona, MN
Kubota L3940; 1942 Farmall H (for sale)
I am thinking of getting a front blade for my L3940 for plowing my 1/3 mile driveway (120' vertical change). My local dealer carries a "local" Wisconsin brand, Berlon. Here's the link to the blade: Skid Steer Snow Blade, Snow Plow Attachment | Berlon. I'd get the 84". With a shoe kit and cushioning valve, I have quote of $2,525. Thoughts?
Thanks in advance.
/ Front Blade #2
Looks like a nice plow, and 1500 less than what I just paid for a LP 8'er.
/ Front Blade #3
That looks like a nice blade.
Just find out the weight and make sure it's not too heavy for your compact tractor.
Travis
/ Front Blade
Dealer says it weighs 725lbs. Specs on the loader are: Lift to full height (at pin): 1,867 lbs [846 kg]; Lift to full height (at 500mm): 1,415 lbs
/ Front Blade #5
If that price includes the hydraulics(third function) it's a very good deal.Looks like a very nice plow.
/ Front Blade #6
Just remember, implement weight on the three point hitch transfers weight/traction to the rear wheels through the two Lower Links and to the front wheels through the Top Link.
A plow on the front lifts weight off the rear wheels and transfers some to the front wheels. You will need functioning 4-WD for sure and probably tire chains, front or front and rear, depending on conditions and what tires are on the L3940.
You may be happier with a rear/angle blade or snow blower on the three point hitch, rather than a plow in front.
Implement/plow functions on a Skid Steer, fundamentally a PUSHING machine, are NOT a guide to how same will work on a tractor, fundamentally a PULLING machine.
I would question the dealer closely, especially as to return policy.
/ Front Blade
Jeff,
The plan is to use my 84" rear blade kicked out and angled to help push the sides back. I have AWD, R4's and filled rears.
The dealer did warn me about tweaking the loader.
/ Front Blade
nybirdman--it does include the hydraulics.
/ Front Blade #9
Jeff,
I would say you are ready. Good plan to have the rear blade back there for traction. R4s, filled. NO FEAR.
Let it snow, let snow, LET IT SNOW.....but not in Florida.
/ Front Blade #10
This blade started out as a 100 gal upright LP tank front&rear plow.jpg made everything but the hoses & hyd cyl. It is used on my 900" and also off property.
/ Front Blade #11
I have an 8' western pro blade on my L4400 and it works great. Just mounted it to a quick-tach plate for the loader. I have about 500 lbs of weight on the 3-point and loaded rear tires with chains and can plow just about anything. With the plow on the loader I am able to pile snow 10 to 12 feet high. Growing up on a farm all we had was a tractor with a 3-point blade and this is so much better!
/ Front Blade #12
I don't like that style of blade, I have one similar to it. When you start pushing snow a with a blade that requires you to use float on the loader it takes weight of the front and it will push the tractor sideways. It is also a alot of weight riding on the skid shoes, you have the weight of the blade and the loader riding on them. They will tear up gravel bad. I recommend a blade that floats at the quick attach to avoid these problems.
/ Front Blade #13
This is my set up, cannot imagine anything working better front blade wise. Probably more expensive, takes longer to mount/dismount, and takes up more room to store, but you will not be disappointed with performance or stength. Philip.
/ Front Blade #14
Just a little more info. I welded ears on the quick-tach plate to attach the blade so the blade floats independent of the loader just as it would on a truck mount. For the hydraulics I ran hoses from my rear remotes for the blade so I still have full use of the loader for adjusting angle of attack if needed for hard packed snow.
2005 Peterbilt 357 Tri-Axle Dump Truck (A66736)
2005 Peterbilt 357...
2011 FORD CROWN VICTORIA CAR (A66091)
2011 FORD CROWN...
275/70R19.5 Tire and Wheel (A68134)
275/70R19.5 Tire...
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
Unused Land Pride SGC1560 Hydraulic Claw Grapple Skid Steer Attachment (A66734)
Unused Land Pride...
2016 Mazda Mazda 6 Sedan (A66738)
2016 Mazda Mazda 6...
