Front blade on Jinma 284
   / Front blade on Jinma 284 #14
Thanks for the compliments. Here's how I did it. I already owned the Meyer plow and bought it new a long time ago. I have no welding equipment so I brought the "A-Frame" from behind the plow to a local weld shop and had them cut off everything I didn't want. Per the photo below I was given the two triangular brackets on each end that are connected to the loader arms. They came from a firm already in the business of making a loader snow blade. Same story for crossover valve. In the photo you can see the brackets with the loader pins but no reinforcing bushings. Next I made a model of plywood and kept adjusting the model until it was right. Then back to the weld shop for prefab and tacking. Then back home and onto the loader for a final check before it became all boxed in.
The angle cylinders run off the front remotes controlled by the valve in the picture. With a lot of help from 3RRL I added these valves, rear remotes, and front remotes.
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
16ft Trailer (A50322)
2019 VOLVO VNL760 TANDEM AXLE SLEEPER (A51219)
2019 VOLVO VNL760...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
