Front axle plug on 7510HST
   / Front axle plug on 7510HST #1
jw_NC
I’m trying to check the case fluid on my front axle. There’s a plastic plug on the left side. I’m afraid of forcing it out. I’ve tried to rotate it. It doesn’t seem like it screws in. However, I can’t manage to pull it out and I don’t want to use a tool to leverage it and risk breaking it.
Have people experienced, similar problems or have any suggestions?
Thanks!
   / Front axle plug on 7510HST #2
That is the breather. You need to consult a shop manual for the correct level plug.
   / Front axle plug on 7510HST #3
Try a little penetrating oil, the level check gauge has an o-ring seal and just pulls out. Depending on how cold it is where you keep it, warming it up to room temp would help as well. My B26 was also a bear to get out the first time - it was clear the o-ring never got any lube from the factory. Shoot a little WD at the plug to case interface and work the head of the gauge to help the oil find the o-ring. Pliers may be needed. After getting the gauge out, wipe off any wd off and put some axle oil back on the o-ring before re-installing. Messick's B7510 Parts has a pic of the fluid gauge.
Thanks!!
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
2022 BARFORD TR8048 MOBILE SCREEN (A51242)
2022 BARFORD...
Toro 3100D (A50324)
Toro 3100D (A50324)
2014 Case IH MD92 Disk Mower (A50515)
2014 Case IH MD92...
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
TRAILER AXLE (A51244)
