Front axle pivot point greasing 4035
/ Front axle pivot point greasing 4035 #1
DutchUncle
Hartland, MI
Mahindra 4035
I have a 4035 Mahindra that has two grease zerks near the front axle. Mahindra calls them "pillow blocks" in the manual. I've greased them, but don't know how much to apply, I can't hear it or see it to know it's full. Any thoughts?
/ Front axle pivot point greasing 4035 #2
Without knowing who prepped your tractor, I usually put 15-20 pumps in this section before delivery.
If its quite full already and you have a battery powered g gun, the gun itself will provide you a clue as it will strain to put any more grease in.
Thank you, so what I'm hearing is that I can't really over grease it.
/ Front axle pivot point greasing 4035 #5
Yes you can most certainly over grease an enclosed bearing. Over greasing creates heat and eventual seal failure.
Look at the area being greased and study the volume output of your grease gun w one squeeze or trigger pull.
Asceratin how many squirts you'll need to grease the area.
For instance, a front tractor axle pivot assembly needs about 15-20 strokes when prepping a tractor for the first time.
It's a large enclosed area on a Mahindra hence the amount of grease.
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
429835 (A61166)
429835 (A61166)
Case IH 4200 Combo Mulch (A66285)
Case IH 4200 Combo...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
