Front Axle Pivot Cracked
/ Front Axle Pivot Cracked #1
Ron Henderson
Hi Guys,
Yesterday after bush-hogging my pasture I noticed some hydraulic fluid dripping off the bottom of my front differential.
Upon further investigation I found that the pivot/holder housing had cracked all the way around, causing it to leak fluid.
This housing mounts to the front of the differential.
I just ordered a new housing with new o-rings.
I'm just curious if anyone has even done this job before?
It looks pretty straight forward.
Thanks,
Ron
/ Front Axle Pivot Cracked #2
Hi Guys,
Thanks,
Ron
Can you show us a picture?
I'll try to get a picture this weekend, the tractor is 18 miles from me at the moment.
It is cracked around the pivot housing that is bolted to the front of the differential with 4 bolts.
The other end is bolted to a cross member with 2 bolts and this end has a grease fitting.
I really don't remember hitting a hole or anything harder than what is normal.
It is located at Fig 5-2-1 G-400 part #23 Holder/Pivot in the online parts manual.
Ron
/ Front Axle Pivot Cracked #4
Ron
This is what I bought for my 5740c when it had same issue. Simple job
Yep, I finally got my tractor back together last week.
I ran into a week delay on my parts shipping out.
It cost me approximately $150 for the pivot and a couple of o-rings.
Like you said, pretty simple job, glad it’s fixed.
Ron
