Front Axle Pivot Cracked
/ Front Axle Pivot Cracked #1
Ron Henderson
Hi Guys,
Yesterday after bush-hogging my pasture I noticed some hydraulic fluid dripping off the bottom of my front differential.
Upon further investigation I found that the pivot/holder housing had cracked all the way around, causing it to leak fluid.
This housing mounts to the front of the differential.
I just ordered a new housing with new o-rings.
I'm just curious if anyone has even done this job before?
It looks pretty straight forward.
Thanks,
Ron
/ Front Axle Pivot Cracked #2
Hi Guys,
Thanks,
Ron
Can you show us a picture?
I'll try to get a picture this weekend, the tractor is 18 miles from me at the moment.
It is cracked around the pivot housing that is bolted to the front of the differential with 4 bolts.
The other end is bolted to a cross member with 2 bolts and this end has a grease fitting.
I really don't remember hitting a hole or anything harder than what is normal.
It is located at Fig 5-2-1 G-400 part #23 Holder/Pivot in the online parts manual.
Ron
/ Front Axle Pivot Cracked #4
Ron
This is what I bought for my 5740c when it had same issue. Simple job
Yep, I finally got my tractor back together last week.
I ran into a week delay on my parts shipping out.
It cost me approximately $150 for the pivot and a couple of o-rings.
Like you said, pretty simple job, glad it’s fixed.
Ron
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
Tennant M30 (A64127)
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
Dueling Tree (A65640)
20' Reids Trailer (A62613)
20' Reids Trailer...
2009 Infiniti G37 Coupe (A64557)
2009 Infiniti G37...
