Oil & Fuel Front axle oil
/ Front axle oil #1
gboudreau
Seacoast, NH
Kioti DK40
I've got a DK40SE and the manual states you can use gear oil or tractor hydraulic transmission oild for the front axle. I was wondering which one everyone is using?
/ Front axle oil #2
I use Rotella. Great oil, great price.
/ Front axle oil #3
I'm surprised that they say either. There's a big difference in viscosity between the two. My tractor specifies gear oil and for an application that is low speed with high tooth contact pressure, that sounds like the right answer to me.
/ Front axle oil #4
I and it seems many others use 80-90 gear oil.
/ Front axle oil #5
I'm not sure I totally trust the Kioti owners manual. I mean, having just read mine, there are parts of it that hardly make sence. It's not hard to tell it was not written by someone whose first language is english.
I'm reading section 6 right now and it's almost laughable. I'm suprised this was published as is.
/ Front axle oil #6
That is odd. I had the same experience with my old CK20 manual but I was impressed that the new DKse series manual was much improved. I don't have it with me to check on section 6 however. I also thought the bigger maintenance manual was pretty clearly written (or at least carefully edited) by a US born engineer (technically precise with perhaps imperfect English but clearly not a haphazard translation).
/ Front axle oil #7
I wasn't going to bother with the maintenance manual, I figured if it was anything like the owners manual it'd be useless. I try to check out a copy.
go ahead and check out section 6 on the Three-Point hitch. just some examples:
  • A rear wheel-tread must be wider than normal when a draft work done and you drive down the slope.
  • Instead of applying a balance weight, never try to load a person or any other object.
  • Be aware and cautious about the surroundings of your tractor turning round if any strangers or object.
For the Top Link
Hole A - Haulage is not required
Hole B - heavy haulage
Hole C - Light haulage
then on the next page it says use A or B if haulage not required and C if haulage required as a tiller.
:confused: While those with years of experience could probably figure some of this stuff out, I bet someone new to tractors would be confused.
/ Front axle oil #8
My boy's bought me a shop manual for my CK20 for Christmas and I found it to be very thorough in some areas and very lacking in others and in some places things are lost in translation but I'm still happy to have even so. Gary
/ Front axle oil #9
Yes, it is bad but I've seen worse writing and grammar on TBN.:eek: I wouldn't bet the house but it still seems as though it was written by a native English speaking engineer or technical writer with either no review or review by a piss poor editor. Real Korenglish is not just unclear but much funnier.:)
There were a few examples like that in the maintenance manual but I am generally very impressed with it. Take a look at it if you do anything more than oil/filter changes on your own.
/ Front axle oil #11
I use 80-90 gear oil.
Honestly did not think of using anything else.
I have a fluid change coming up soon.
Joel
/ Front axle oil #12
my owners manual for my ck30 with is 6 months old,is very good. Apparantly some are and some ain't,[glad I got a good one].
Case SV280B (A62177)
2022 EZ-GO ELITE...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
2007 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRK (A64277)
2007 FREIGHTLINER...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
NEW 2025 Trailer by Premiere Single Axle 12' Tilt  (A62679)
NEW 2025 Trailer...
