Front axle leak
/ Front axle leak #1
Anonymous Poster
Epic Contributor
The last time I used my L3010 HST I noticed a little fluid leaking around my right front tire. It was the first time I had noticed it dripping, but it only left about a 2" diameter spot on the concrete. After using it yesterday for some landscaping I noticed that it left a bigger spot, probably 4"-6" in diameter. The past two times I have used it have been in a real sandy soil. Could I have gotten some sand lodged in a seal and damaged it to cause this leak? /forums/images/graemlins/confused.gif
I will probably have plenty of time to work on it this weekend, because it is raining a lot right now, as it has been for some time now. /forums/images/graemlins/frown.gif
Thanks for any help.
/ Front axle leak #2
dboone,
As a really simple check, did you make sure that your oil addition/vents on the axle are tight? My wife noticed a little oil underneath my BX2200 up front, and sure enough, the axle oil check/addition thingy was loose. I was happy she saw it then, versus me figuring it out when the part was laying somewhere on the property...
/ Front axle leak #3
Just a thought, is the oil level in the axle above full? Could it be thermal expansion? I found that one of my fill plugs had become loose and a bit of fluid had leaked out.
/ Front axle leak
It was raining last night when I got home last night, like it has been for a month it seems like. So I have not taken the time to check it out. My dad had actually borrowed my tractor yesterday while I was at work.
The sun has been coming out during the day, but when 5 o'clock rolls around the rain sets in. Has given me very little seat time here lately. I am hoping to get a break from the rain long enough to check things out one afternoon this week. If not I will pull it into my enclosed shop to check into it this weekend. I am hoping it is something simple!
Thanks for the suggestions. I have to remind myself to keep it simple every once in a while.
/ Front axle leak
Everything is tight on my axle and the fluid level is fine. It is leaking at the very bottom. It looks to be around what appears to be a keyway slot. There doesn't appear to be any difference in between the left and right sides, but the right side drips just a little. I can't find any cracks or anything that would cause it to leak. Any suggestions?
215025 (A64276)
215025 (A64276)
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
RoGator and Terragator Manuals (A63117)
RoGator and...
1998 Freightliner MT45 Step Van Food Truck (A61573)
1998 Freightliner...
2026 Electric Tricycle (A64194)
2026 Electric...
