front axel oil change
   / front axel oil change #1
BC2009
Massey Ferguson 1035
Hey all, 1035 Massey front axel/differential oil change. What the F$%# is the easiest way to refill. Tiny fill holes in horrible spots is the only way? Thx in advance
figured it out.....mistakes make you smarter....xo
   / front axel oil change #4
I've a funnel with a long snout on it and a tappering hole at the end of the snout that I use to get liquids into tough spots. Didn't make it. Got it somewhere but do not recall where.
You could Goop a hose to the end of a regular funnel and get it done that way. Just let the Goop sit overnight.
   / front axel oil change #5
I use an empty gear oil bottle (because I use UDT in my tractors front axle) with pointed spout and just squeeze it into the filler holes.
   / front axel oil change #6
Easiest way to fill it is "patience" I refilled mine with thicket gear oil and talk about sloooooow.
   / front axel oil change #7
I have a steel flex spout funnel. The flex spout is about 12" long and ends with a small tip. I take VERY GOOD care of this funnel. Never been able to find anything/anywhere exactly like it. AND I have no idea where I got it.
   / front axel oil change #8
Just remember - the engineers that design these tractors NEVER have to pull maintenance on them.
   / front axel oil change #9
Amsoil packages gear oil and trans fluid in optional "bags" that works great. So much easier to fill rear ends, front ends and transfer cases without making a mess. I think Valvoline has taken their idea as well.
2nd option is the little cheap plastic pumps that attach to a quart bottle. The work good until either the hose comes off or the suction tube.
   / front axel oil change #10
Sometimes you just have to be creative. When I was a kid I needed to fill the transmission in my 1948 Dodge I could not get to the fill point with a funnel. I ended up using one of my mom's rubber gloves from under the sink, cutting the end of a finger, filled the glove with 90Wt, put the finger in the hole and squeezed the gear lube in. :)
Adapt and overcome.
JOHN DEERE 24" PIN ON EXCAVATOR BUCKET (A52707)
JOHN DEERE 24" PIN...
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
KUBOTA SVL95-2S SKID STEER (A52707)
KUBOTA SVL95-2S...
2013 BMW X5 xDrive50i AWD SUV (A55758)
2013 BMW X5...
Heavy Duty Ratchet Binders and Chains Set (A53425)
Heavy Duty Ratchet...
2025 Epic Electric Golf Cart (A55758)
2025 Epic Electric...
