front attach mowers
/ front attach mowers #21
Check out this eBay auction: Ford Versatile Bi
Funny thing is that if you drive it backwards (which would give you the best view), the mower is on the wrong side, (correct for England and Bermuda but not around here).
/ front attach mowers #22
With the ditch bank mower you would want to drive it like a conventional tractor. It helps to keep the tractor in line and you looking ahead instead of always looking down into the ditch. That auction also has a nice brush chopper for the cab side that you can drive cab first with.
The gas company is using that setup around here to clear the gas lines. Has a big root rake on the cab end and the 10' brush chopper on the engine end.
/ front attach mowers #23
Forage harvesters are in the $150k+ category and are a different beast. Claas, Krone and a few aftermarket companies make tri gang mowers for their forage harvesters to give you a self propelled mower and make your $150k machine more versatile. But Forage harvesters are designed to pick up forage and chop it up into tiny bits for feed where as the Bi-Directional mowers are designed for cutting hay to either be baled up or to be chopped up by a forage harvester.
/ front attach mowers #24
TN has mechanical front lift, produced by SAUTER.
Front PTO, electrohydraulic engaged, is mechanically driven from front side of crank.
/ front attach mowers #25
And hitch and PTO on new model TNS-A looks similar ...
/ front attach mowers #26
... and have electronic control (upper left)
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2001 Mack RD688S T/A Galbreath Roll Off Truck (A61573)
2001 Mack RD688S...
2017 Caterpillar 308E2 (A64126)
2017 Caterpillar...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
7 Barrel Masport Vac Pump (A62679)
7 Barrel Masport...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
