From a B3030HSDC to a Toolcat?
   / From a B3030HSDC to a Toolcat?
There's also the matter of moving, placing and compacting over 1,000 cu. yds. of fill to raise the house and surrounding area. And moving materials around the house during construction. The lift capacity of the Toolcat loader being almost double that of the B3030 was the thing that initially got my interest.
   / From a B3030HSDC to a Toolcat? #52
OD,
I think Sky is talking about the actaul GPH the machine burns, not how efficient it is. It's a 56hp turbo...it's going to burn diesel. Yeah it may be "efficient" compared to some other comparable hp machines, but it certainly won't be a sipper.
Ramblings below:
Don't get me wrong and I love the Toolcats....A good friend of mine has one for his landscaping business. It's used in the yard all day. It's a commercial machine used to move trees, load mulch and topsoil, blow snow from parking lots in the winter and such. From what I've seen, I don't feel it's the right machine for a guy with 5 acres, 4 of which may be mowed. It's an awesome machine for the right conditions and jobs. It's NOT a "do-all" IMO. Bobcat makes no suggestion that it is made to replace a tractor. It was not designed to replace a tractor. They are completely different species and I would think that is obvious to everybody. I may own one someday, but I'd never consider it a replacement for my tractor. It would be in addition and it would be secondary. A toolcat would be belly-high the first five minutes on my property...stuck in the mud and rocks so badly I'd have to have a excavator remove it. It would also crush my lawn badly and likely wouldn't have a lawn. It is not designed to mow private property...it's not a lawn mower. Might work well for a big site like a school yard or something like that. Yes, they make a mower for it, does that make it a lawn mower? You want a nicely cut and managed lawn, get a good commercial zero-turn mower designed to cut lawns.
The Toolcat has an awesome box on the back for material and tools. How are you going to load the box with material...Are you going to shovel it by hand? Bobcat knows that most companies that buy these machines have a general purpose utility tractor on site. As mentioned by others.
Weight....How are you going to transport it? Do you have a pickup and a big enough trailer for the machine and it's attachements. Maybe it will live it's entire 40 year life on the five acres.
Why are they being compared?....Because the potential buyer though he wanted a tractor and now found a cooler toy. If it's all about having a toy, I'd say you can get away with a Toolcat and a real lawn mower (forget the mower attachment). If you want a machine that will do "everything", look again at a smaller CUT (not necessarily a Kubota). A small cut with big, soft turf tires and a high RPM deck will mow the lawn well and mow it quickly. It will do what you need on the property as you mentioned. It will not handle the kids and the dogs, unfortunately. If you said you have 40 acres and a finished house and a tractor, the Toolcat would indeed be a fine addition in the garage for general utility and just plain fun.
It's not about the $$ for me, it's about the effective uses for the machine. I just don't see a Toolcat being the one machine to own long term. In combination yes, solo, no. It's not a lawn mower.
Remember, you'll need to maintain multiple machines in order to do the jobs you want (correctly). There is no universal machine, or we'd all have one. Every "profession" has mutiple tools. There are different tools for different jobs and that will never change.
   / From a B3030HSDC to a Toolcat? #53
It is not a lawn mower and has not been marketed as such. It will "mow" a lawn, but a mower it ain't. Have you ever seen an 4,000lb lawn mower with super hard tires and sidewalls? If you have, it wasn't running across a private individuals lawn. Most grasses aside from commerical grade, hardy varieties can't take that kind of abuse long term. The mower is basically a brush hog for "dense grasses and golden rod"....As stated in Popular Mechanics.
   / From a B3030HSDC to a Toolcat? #54
Definitely worth considering, but what are you going to be moving....There is no soil or material heaping full and spilling over that the 3030 won't lift.
I know where you're coming from....I've done it twice. I would seriously consider hiring a dozer for the afternoon to make quick and professional cut/fill grading around the house and use your new machine (whatever it may be) to finish the job.
Jim,
You make a lot of valid comments that I need to think about. I appreciate the time you've taken to put them down and hopefully folks won't mind a longish post to respond to them in some detail. Here are some thoughts:
</font><font color="blue" class="small">( I think Sky is talking about the actual GPH the machine burns, not how efficient it is. It's a 56hp turbo...it's going to burn diesel. )</font>
They also make a 46 hp model that I need to consider. It would certainly be strong enough, it's just that the price increase is only about $1,800 which didn't seem like a lot for a 10 hp bump. How significant is the increase in fuel use?
I think a lot of folks are looking at the hp rating and comparing it to tractors. A 56 hp tractor would be a behemoth that would barely fit into a 5 acres lot! But I don't think the comparison is appropriate. No one would ever assert that a 300 hp truck would have more capability than a 56 hp tractor. It's apples and oranges. The horses are going to different uses, speed verses torque, etc. I think the same analogy can be applied to the tractor versus Toolcat. The Toolcat is built to lift with the FEL, just like the tractor, but the Toolcat is also build to be able to carry and dump a 2,000 lb load, and pull a 4,000 lb trailer. It can also run at 18 mph.
</font><font color="blue" class="small">( Bobcat makes no suggestion that it is made to replace a tractor. It was not designed to replace a tractor. )</font>
I agree, but I'm questioning whether a tractor is the best machine for all the things I need to do.
</font><font color="blue" class="small">( A toolcat would be belly-high the first five minutes on my property...stuck in the mud and rocks so badly I'd have to have a excavator remove it. It would also crush my lawn badly and likely wouldn't have a lawn. )</font>
I have sand, no rocks, and a water table that is 40 ft. below the surface. you can't make mud on my lot, even in heavy rain. Besides, I don't think you give enough credit to 4-wheel drive with the load evenly spread to four equally sizes tires. Which is also a factor in how the weight will affect the lawn. Again, you can't compare, pound for pound, how a Toolcat's weight will impact a lawn verses a tractor. They don't stand and move on the lawn in the same way. And the Toolcat weights 4,800 lbs., not 8,000, where did you get that number? It doesn't carry the weight of the mower, although that wouldn't be 3,000 lbs. anyway.
</font><font color="blue" class="small">( The Toolcat has an awesome box on the back for material and tools. How are you going to load the box with material...Are you going to shovel it by hand? Bobcat knows that most companies that buy these machines have a general purpose utility tractor on site. )</font>
That's a very valid point. It would be nice if it could load itself! But this part is not that important to me. I'm looking at the truck bed in terms of carrying tools or 2x4's or potted plants, not dirt. Right now, I don't see the need for the dump function. The dump trucks will place the fill I need where I need it. From there it's loader work. I don't see my needing to move a lot of dirt around. If that changed in the future, I would need to think about some small loader to use with it.
</font><font color="blue" class="small">( Weight....How are you going to transport it? Do you have a 3/4 pickup and a big enough trailer for the machine and it's attachments. Maybe it will live it's entire 40 year life on the five acres. )</font>
Actually, this one isn't that hard. I can pull 7,200 lbs with my 1/2 ton Yukon XL, and an 18 ft. 7,000 lb aluminum trailer will leave me 5,620 lbs of carrying capacity. Enough for the 4,800 lb Toolcat and some implements.
</font><font color="blue" class="small">( Here's what I would get: 3030 tractor or similar CUT with a mower deck... )</font>
My main concern with the B3030, which was my final choice in tractors, is that the loader capacity was a compromise from the beginning, and still bothered me to the end. I don't think 800 lb lift is enough for what I need. To get enough lift in a tractor I'd have to go to something like the L3130, which in a tractor configuration weighs too much to mow with and would tear up the lawn even in 2-wheel drive. And to get a cab, I'd have to go to an L3430, which would be even more weight.
</font><font color="blue" class="small">( Remember, you'll need to maintain multiple machines in order to do the jobs you want (correctly). There is no universal machine, or we'd all have one. Every "profession" has multiple tools. There are different tools for different jobs and that will never change. )</font>
Again, very true and valid. It's just that I'm not mechanically inclined, and to the extent that I could manage with just one machine, it would make my life a lot easier.
I forgot one other thing. With the tree clearing I need to do over a long period of time. I want to clear just enough for the house initially, then over time I will selectively clear more trees. I want to do it this way so that I end up with as many trees as possible while not living in a jungle. Right now I have full tree cover.
The weight and loader capacity of the Toolcat will make that work a lot easier than the B3030 would. The B3030 is capable of it, it would just take a lot more effort.
I know that renting equipment and even paying people to do this work would probably make more economic sense. I would hardly even need a tractor if I only got something to mow at the end of the process. A zero-turn would be better. It's just that I want to do this work myself. For the fun of it, and because I would take more care than anyone I could pay to do it for me. I know that I'm going to have to pay some premium for that preference.
By the way, I really appreciate Jim's and all the other comments questioning the suitability of the Toolcat for me. They test my conclusions and will help me make a better choice, whatever it is.
   / From a B3030HSDC to a Toolcat? #56
Knowing that you are not mechanically inclined, how do you propose to take care of your Bobcat without the proper tools, time, and personal energy?
Keeping it maintained properly is no joke and your nearest dealer is how many miles away??? Sure they are glad to sell you one, but you'll be relying on them for service and parts and you are not a major equipment operator.
For someone with little experience operating and maintaining any of this kind of equipment, my personal belief is that this choice is a major mistake for you, you'd be better off in the short run and long run with a CUT. /forums/images/graemlins/wink.gif
But is a CUT going to take any less maintenance or care than the Toolcat? Or are you thinking that Kubota has a good dealer right here in town? That's definitely a factor, although where I am west of town, it won't take too much longer to get to the west side of Ocala as it will for me to go all through town to get to the northeast of Gainesville.
   / From a B3030HSDC to a Toolcat? #58
You'll have to discover that fact for yourself when it comes to maintaining that equipment.
Have you checked out accecessibility to important maintenance items on your Bobcat (radiator, filters, hoses, air filter, air conditioner, hydraulics, instruments, etc)., they sure are severely cramped in my opinion? A turbocharged diesel engine needs to be maintained in detail to prevent costly wear and down time, the maintenance of which is no accident.
I have a complete mechanics tool shop with compressors, welders, torches, pumps, tanks, lifts, winches, sockets, etc. etc. etc. to keep my fleet of diesels operational 24-7. I don't think you are envisioning that kind of maintenance requirements for your investment. Just purchasing the required tools is a major undertaking seeing as you'll little to start out with.
I'm going to try posting to see if anyone has experience dealing with Bobcat and Kubota of Ocala. It was very helpful hearing your comments about Gatorland Kubota in gaining me a level of confidence about them.
   / From a B3030HSDC to a Toolcat? #60
The worst thing about owning equipment is owning equipment that isn't working because things only break when you are working at it hard. (Don't ask me how I managed to learn this first hand.) /forums/images/graemlins/tongue.gif
Having to wait for a repair part or repair service for weeks in the middle of an important job is Extremely Frustrating , especially when the job can't wait......
Good luck getting it figured out, but I think you may be getting in over your head and would be allot easier off sticking with a medium CUT. /forums/images/graemlins/wink.gif
2010 John Deere 8329R Tractor (A59814)
2010 John Deere...
SCREENER (A58214)
SCREENER (A58214)
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
20' 1 Trip Shipping Container (A59814)
20' 1 Trip...
2017 BX2680 Sub Compact Utility Tractor (A56436)
2017 BX2680 Sub...
