Freeze plug or core plug, need advice, Ford 1700
   / Freeze plug or core plug, need advice, Ford 1700 #1
rayikeo2
Platinum Member
I just read mostly_gas's thread and I may have the same or a similar problem. I may have the same problem, need advice. I just started my 1700 and while changing implements and letting it idle, the guage went to hot. I lifted the hood and saw what looks to be antifreeze comming from between the gas tank and the rear of the engine. My question, is there a freeze plug or a core plug there, or niether? I can not see it without taking the tank off. Is this something I can fix myself? Where did you get your plugs?
   / Freeze plug or core plug, need advice, Ford 1700 #2
Soundguy, what is the easiest or best way to get the old plug out?:confused:
   / Freeze plug or core plug, need advice, Ford 1700 #4
hammer,screwdriver and pair of pliers.. either knock a hole in it's center ..push screwdriver in about half inch and then twist it to the side and pull out with pliers.. or tap it near a side edge witht he screwdriver till it spins... then yank out..
they are soft metal.. they give way pretty easilly.
soundguy
2018 HINO 268  NON CDL 26FT BOX TRUCK (A52576)
2018 HINO 268 NON...
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
2004 PETERBILT 379 9 CAR HAULER (A52577)
2004 PETERBILT 379...
2009 Volkswagen Jetta Passenger Car (A51694)
2009 Volkswagen...
