Freeze plug or core plug, need advice, Ford 1700
   / Freeze plug or core plug, need advice, Ford 1700 #1
rayikeo2
Platinum Member
I just read mostly_gas's thread and I may have the same or a similar problem. I may have the same problem, need advice. I just started my 1700 and while changing implements and letting it idle, the guage went to hot. I lifted the hood and saw what looks to be antifreeze comming from between the gas tank and the rear of the engine. My question, is there a freeze plug or a core plug there, or niether? I can not see it without taking the tank off. Is this something I can fix myself? Where did you get your plugs?
   / Freeze plug or core plug, need advice, Ford 1700 #2
Soundguy, what is the easiest or best way to get the old plug out?:confused:
   / Freeze plug or core plug, need advice, Ford 1700 #4
hammer,screwdriver and pair of pliers.. either knock a hole in it's center ..push screwdriver in about half inch and then twist it to the side and pull out with pliers.. or tap it near a side edge witht he screwdriver till it spins... then yank out..
they are soft metal.. they give way pretty easilly.
soundguy
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
LEONARD 16 ENCLOSED TRAILER (A52472)
LEONARD 16...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2016 Kia Cadenza Sedan (A51694)
2016 Kia Cadenza...
