Freeze Plug in John Deere 855 tractor leaking
   / Freeze Plug in John Deere 855 tractor leaking #1
Donna Belcher
Millersville MD
855 John Deere
how hard is it to remove? the freeze plug and how do you do it
   / Freeze Plug in John Deere 855 tractor leaking #2
Welcome to TBN!
Generally speaking, just a hammer and a chisel or screw driver....hammer in on one side, which rotates it until you can grab it with vice grips, and pull it out. There are lots of videos online that show how to do it...worth watching one or two.
   / Freeze Plug in John Deere 855 tractor leaking #3
Welcome!
Once you get the old one out, if its hard to access, they make a rubber expandable plug type that works well. It has a bolt through it with a nut that you tighten, which causes the rubber plug to expand. Similar to a boat drain plug. Most auto parts stores have them.
Good Luck!
   / Freeze Plug in John Deere 855 tractor leaking #4
Gently, they are thin metal you can punch a screw driver threw near one edge then pry it out enough to get hold of it with pliers if necessary.
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
Parker 250 bu Gravity Wagon (A50515)
Parker 250 bu...
2022 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2022 JCB HM180T...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A51039)
John Deere 1110...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
