Freewheel 2310
/ Freewheel 2310 #1
New Hampshire
Massey Ferguson GC2310
Quick qestion guys... didn't see it in the manual. Is there a way to put it in true neutral, like a freewheel mode?
Needed to roll it back a few inches and for the life of me can't figure out how.
/ Freewheel 2310 #2
Putting it in N should do it. Taking it out of 4WD will help it move easier since the front and rear wheels move at a slightly different ground speed. If you still have a problem then the brakes may be dragging and need adjusted.
Doug
/ Freewheel 2310
Yeah, I tired again and I was able to roll it. Don't know if maybe the brake was engaged when I was trying last time. Was pulling on the only history I have with Hydro transmissions (Sears Tractor). Those require you to manually put it in freewheel.
Thanks!
/ Freewheel 2310 #5
Is there any harm in doing this?? We have a 1523Hydro, and when working on our driveway, it is easier to let it roll ahead a few feet, rather then starting it up every few minutes??
Thanks,
Will
C&S FARMS AUCTION - IN LOVING MEMORY OF JACKSON STRICKLAND. (A64277)
C&S FARMS AUCTION...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
Lot of (3) HD Pipe Gates (A66408)
Lot of (3) HD Pipe...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
2009 International 8600 (A62613)
2009 International...
2024 MODASA  MH-25 I GENERATOR (A65643)
2024 MODASA MH-25...
