Free Log splitter
/ Free Log splitter
I believe your tractor s a closed center system.
Here are the specs.
Hydraulics:
Type: closed center PFC
Capacity: 25.4 gal [96.1 L]
Pressure: -unknown-
Valves: 2 to 4
Valve flow: 18.9 gpm [71.5 lpm]
TractorData.com John Deere 6410 tractor information
So what does this mean in terms of using the log splitter with this tractor? It has two lines to plug into the back of the tractor, one for each cylinder. What type of valve would I need for each of the cylinders if I choose to replace them, which i probably will do, as the valves on there you have to hold the levers to extend and retract the cylinders.
/ Free Log splitter #22
mudbug250,
Here is a closed center log splitter valve if you want to use the splitter with your tractor, and you can not convert the other valve.
Surplus Center - 1 SPOOL 30 GPM CLOSED CENTER LOG SPLITTER VALVE
To test your current log splitter valve for closed center, remove all the hoses and put air in the IN port. With the lever in neutral, no air should come out of the valve. Then, if you move the lever, air should flow out the work ports.
To test for open center, connect air to the IN port, and air should flow out the OUT port in neutral. If the valve has PB, then air will flow out the PB port. If you move the levers, air should come out the work ports.
/ Free Log splitter #23
mudbug250,
You need to determine which valve you have.
If you want a true log splitter valve with detent, you need a log splitter valve.
The valve on there could be any type valve.
There are valve that you have to hold the levers open for both operations.
Some valves have detent on one or both.
An Autovalve has two levers that once set, the cyl will extend and retract and return the lever to neutral.
So test your current valve first and let us know what you have and if it had detent.
This two lever valve will operate the log splitter and another cyl.
http://www.surpluscenter.com/item.asp?item=9-7414&catname=hydraulic
/ Free Log splitter #24
mudbug250,
As far as the two hoses, it depends on where the hoses connect.
One of them is the pressure hose and it will go to the IN port on the log splitter valve. The log splitter out hose could go to tank. Trace the other hose from the tractor and see where it goes.
Is your hoses on the back coming from a valve or is it just a QD?
If you decide to go stand alone, you will need an open center valve with the two stage pump as the engine driven pump is pumping all the time, and the fluid must flow through the log splitter valve.
/ Free Log splitter
JJ,
So I can't just get a new closed center valve without detent for the log lift? I don't care if it has detent or not, just wanted to put a new valve on there for dependability. But would like a detent or autovalve for the wood splitter cylinder to free up my hands.
My father in law and I tested it quickly when I got it and everything worked properly.
I will see if I can get the rest of the numbers/letters off the valve this afternoon. Like I said previously, all I could get off of it last night was Victor Power Fluids DV 121.
/ Free Log splitter
JJ,
I will trace the hoses this afternoon and see where they are routed to and from. But I am guessing it was like you said one pressure out and one was to tank. We only had to use one of the hydraulic controls in the cab to load the entire system.
/ Free Log splitter #27
JJ,
Here is a closed center valve with no detent.
Surplus Center - 1 SPOOL 45 GPM BRAND DA CC VALVE
This valve can be converted to closed center.
http://www.surpluscenter.com/item.asp?item=9-7974&catname=hydraulic
The company that made that valve has been closed down since about 2000.
/ Free Log splitter
JJ,
When we hook to our bush hog, we can raise and lower the hydraulic lift using the one hydraulic line hooked to one of the hydraulic hook ups at the back of the tractor. So it seems to me that these hook ups allow flow of fluid out and in, all controlled by one of the hydraulic levers in the cab. Is this beyond power? And does that change the opened/closed center system conversation.
But I will trace the hoses this afternoon and see how everything hooks together.
/ Free Log splitter #29
JJ,
Don't know if this makes any difference but I am hooking to a power beyond on the tactor.
When we hook to our bush hog, we can raise and lower the hydraulic lift using the one hydraulic line hooked to one of the power beyond hook ups
Actually, you are hooking to the hydraulic remote on the tractor like you would power beyond. Closed center systems like yours do not have power beyond. Power beyond is only available in Open center hydraulic systems.
Aaron Z
/ Free Log splitter #30
Are your tractor valves in parallel, or they in series.
Tractor data says your tractor is closed center , and that means that all valves using the same pump are in parallel. In a closed center system all valve get equal flow if the GPM rating are the same.
If you put a gage in a tee at the FEL valve, do you have system pressure with the lever in neutral?
If you plug a gage in the QD at the back, do you have system pressure.
Option 3 makes that valve a closed center valve.
An open center valve system has no or very little pressure with all valves in neutral.
Can you verify that your tractor has closed center hyd's.
Your tractor may very well have a PB port, but if it is used in a closed center system, the PB port will be plugged.
The below valve from Prince is for illustration.
http://www.princehyd.com/Portals/0/products/valves/SVInstS.pdf
/ Free Log splitter
JJ,
I have no idea, like I said I know nothing about hydraulics. I just know we hook the one hose from the bush hog and it raises and lowers using one port. We also have a do all that raises and lowers using one hose. It also has another port directly below that port that I believe is controlled by another lever in the cab.
The tractor is a 6410. The tractor on tractordata.com looks like it except for the big tires on the front. So I guess it is a closed system.
/ Free Log splitter
No levers on the back of the tractor, only one small switch that lowers and raises the 3 point hitch. The ports at the back of the tractor are controlled by levers that are in the control console of the tractor on the right side of the driver (factory installed).
Would a closed center system be capable of raising and lowering using only one remote port?
/ Free Log splitter #33
Plug a gage in that remote hose and tell us if it has pressure. Plug in the gage before you start the tractor. If it is closed center, and the switch is set right, it should have full pressure , about 2500 psi for most tractors.
/ Free Log splitter
Don't have a gauge. :confused:
/ Free Log splitter #35
Here are two gage test sets made up by TBN members. The 3000 psi gage it self only cost about $12 to $20
Your TSC should have them or any hyd business.
/ Free Log splitter
Will have to get a DeLux coupler connection to add to it. Never mind, I just took a closer look at it, and that one would work.
/ Free Log splitter
So I believe the links above confirmed that the tractor is a closed center system. Now just have to see if the current valves on the splitter itself is open or closed center valves right. And trace exactly where lines go to and from.
/ Free Log splitter
Here is a link showing the valves for the selective controls in the cab:OMAL152877: 6010, 6110, 6210, 6310 and 6410 Tractors(*266767-******), Block File: LX_OZUS004602_19_01MAR00.htm
I believe our tractor has the 100 series or the 300 series. But not completely sure.
So I think this is the set up for the spitter. It has two long hoses, each on has a male end that plugs into a female DeLux coupler at the back of the tractor. One hose goes to the valve controling the splitter and the other hose goes to the valve controlling log lift. Then each valve has two hoses connected to it. One that connects to the back and front of each cylinder. The two valves on the splitter are completely seperated from each other. Not connected.
When we connected it, we worked both selective control levers to get the splitter "charged", ending with the selective control levers putting pressure out to both hoses. Then we went to the log splitter and both cylinders extended and retracted.
2020 Peterbilt PB337 S/A Dump Truck (A61573)
2020 Peterbilt...
UNUSED WOLVERINE HYD MINI 4IN1 BUCKET (A64281)
UNUSED WOLVERINE...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
UNUSED WOLVERINE MINI HYD 4IN1 BUCKET (A64281)
UNUSED WOLVERINE...
2015 Ford Fusion AWD Sedan (A61574)
2015 Ford Fusion...
42" X 27" FIRE PIT RING/DISC (A64281)
42" X 27" FIRE PIT...
