Framtrac 360DTK transmission trouble
/ Framtrac 360DTK transmission trouble #1
Hardways Ranch
FramTrac 360DTC
Transmission trouble on Framtrac 360DTK
Was working and stopped to lift box blade and had nothing no forward or backwards no movement, so checked range H,M,L seemed to be ok, checked gears also seemed ok, checked 4 wheel drive seemed ok, checked forward and backwards seemed ok, clutch seemed to have pressure on it. Took panels off to look at transmission operated and lever and they looked like were moving parts on outside of transmission. Did notice clutch return spring broken. Would that stop tractor from moving or could it be switch start pto module or is it more serious like throw out bearing. Remember nothing felt wrong when stopped no noise or grinding i'm at a lost of where to look.
/ Framtrac 360DTK transmission trouble #2
I have 360 Framtrac It was working fine then it stopped moving forward. It goes very very slow and has no power. Were you able to find an answer to your problem?
/ Framtrac 360DTK transmission trouble #3
I know tis is a long shot but my 300 DTC just did the same thing and trying to find some ideas. Have either of you solved your issues?
