Flail Mower frail mower vrs rear finnishing mower
   / frail mower vrs rear finnishing mower #1
mclogn
meridian ms
mf 261
Hey guys,
I'm building a house in an seven acre hay field. The field is Bahia. The terrain is uneven. I would like a clean and even cut since most of field will be my front yard. I know hardly anything of frail mowers or finishing mowers. Any advice would be greatly appreciated.
   / frail mower vrs rear finnishing mower #2
I think you meant FLAIL mower!!! :thumbsup:
   / frail mower vrs rear finnishing mower #3
A flail mower can be a finishing mower.
The flail has up to 90 blades to cut grass.
The finish mower has three blades to cut grass.
A flail mower with say 40 heavy duty blades would equal a one shaft bush hog.
Thanks for info.Which would you prefer between the two?
Yep sorry
   / frail mower vrs rear finnishing mower #6
IMHO, finish mower would give the best cut (like a lawn tractor), the the flail will be able to do rough work also, where the finish cannot take a lot of abuse with brush (just like a lawn tractor).
If you never want to do rough or brush cutting, get a finish mower.
My $0.02...
   / frail mower vrs rear finnishing mower #7
If the field grasses are too high (no more then 12", for example) and you're sure there are no obstacles in the field, you could try mowing the finish mower set as high as possible.
The field I mow is 3-4 acres (give or take). The grass an brush were anywhere from 12" to 3-4 high. My first mowing was with a rotary cutter to get it down to 6-8 inches. All subsequent mowing have been with a finishing mower and it looks really good. Not "lawn" quality yet, but it's getting there.
So, if I were you, I'd buy a cheap used cutter for the first mowing and see what you have...then make the decision about the flail or finishing mower.
   / frail mower vrs rear finnishing mower #9
If you plan on just having a nice lawn, maybe you should box blade the field until it is flat and even, then seed it and keep it mowed with the finish mower.
   / frail mower vrs rear finnishing mower #10
I agree, smooth it out and replant with a lawn grass. Bahia grass is tough to mow, wears down cows teeth and ain't purty either.:D
New/Unused 7ft Stainless Steel Work Bench with 20 Drawers (A51573)
New/Unused 7ft...
Kubota Salt-Spreader (A52384)
Kubota...
2023 Jeep Compass Trail Hawk 4x4 SUV (A51694)
2023 Jeep Compass...
2020 CATERPILLAR 120 MOTOR GRADER (A51246)
2020 CATERPILLAR...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2012 VOLVO ECR305CL EXCAVATOR (A51246)
2012 VOLVO...
