Foward and backwards
/ Foward and backwards #1
fpfdchief
fort plain,new york
kioti ck20 wcab L6060 grand cab loader backhoe and Kubota L6060 grand w/autohitch
Brand new DK50HST with cab. The HST is faster in reverse than foward. It is the same in all 3 ranges. Went to the dealer and tried another on the lot and it was the same. I have all ready tried adj the pedal stops. still faster in reverse. My problem is not that reverse is to fast, its that I would like to go faster in foward. Any one else have this issue and what was the fix?
/ Foward and backwards #2
Is there a way to reverse the hydraulic control lines @ the motor ??
I wouldn't like that either.
reversing the lines ??? come to think of it...that would be stupid, not to mention dangerous.
MAYBE they're putting the HST drives on backwards from the factory ?
/ Foward and backwards #3
That is odd. Did you mention this to the dealer? All of the Bobcat versions have reverse travel at about 2/3 (67%) of max forward speed, I don't think this is Bobcat specific design.
I just took a look at the pedal setup in service manual. There are adjustable rubber stops on the pedals underneath the platform. Shorten the max travel of reverse pedal. Might want to check the forward setting too, they may have gotten the settings mixed up at the factory. The stop, in forward should contact just before the pedal is at full stroke against it's internal servo piston.
/ Foward and backwards #4
With my DK40 reverse is slightly slower then forward, so there might have been a bad day in the factory when they built yours.
Jason
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2015 DITCH WITCH FX25 VACUUM TRAILER (A63276)
2015 DITCH WITCH...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2020 CATERPILLAR...
