Four in One bucket recommendations
/ Four in One bucket recommendations #1
Gary_in_Indiana
Elite Member
Fort Wayne, IN
John Deere 4200 MFWD HST w/ JD 420 FEL w/ 61" loader bucket & toothbar & JD 37 BH w/ 12" bucket
I've been thinking of getting a four in one bucket for my John Deere 4200 with a 420 loader. Anyone have any suggestions as to what I might want to consider? Thanks. /forums/images/graemlins/smile.gif
/ Four in One bucket recommendations #2
Gary,
</font><font color="blue" class="small">( Anyone have any suggestions as to what I might want to consider? )</font>
I bought the one marketed by John Deere when I bought my 4300 and 430 loader. It appears to be very much like the ATI 4in1 bucket. I also opted for the Fasse valve and joystick control. There is also another manufacturer of 4in1 buckets (can't remember the name) who has posted here recently - he has pictures of a very interesting belly mount grader blade in the photo section. Perhaps he'll jump in here and help.
I use mine for a lot of grapple type work - rooting out and piling brush and moving logs for firewood. The Fasse valve and joystick control was expensive but in four years (over 1000 hours on the tractor) I have replaced one o ring. When I took delivery, the hoses on the bucket were poorly secured. One got pinched between the connector block and the bucket. Deere replaced the hose and I secured both hoses with heavy tie wraps. I have since had one other hose fail. I had my local hydraulic shop make a replacement out of a heavier walled material. The made it up while I waited and charged me about $6.00.
Does your 4200 have the three position lockout on the DSCV? If you are going to use the DSCV to control the bucket, it's nice to be able to lock out the regenerative dump (middle position). Otherwise you will need to pipe it so that the same action that dumps the bucket closes the grapple. Mine was delivered that way and I knew after about a half hour that it was counter intuitive and needed to be reversed.
/ Four in One bucket recommendations #3
I am in the process of putting together a tractor package, and was given a recommendation by a very knowledgeable membe on this site to get a 4 in 1 bucket.
I talked to a dealer about it, and the dealer doesn't like them, claiming that they bend and warp and have mechanical problems.
I like the idea of the versatility of such a bucket, but my question is if you can get a 4 in 1 bucket that's as heavy duty as a heavy duty standard bucket? Strength and durability are important to me, and I wouldn't want to spend thousands of dollars on an attachment if its going to fail. Tony
/ Four in One bucket recommendations #4
Tony,
</font><font color="blue" class="small">( I talked to a dealer about it, and the dealer doesn't like them, claiming that they bend and warp and have mechanical problems. )</font>
The only bending problem that I have had is the two teeth on the top section that act as grips when using the bucket as a grapple. I have bent them several times while handling logs that were probably too long and too heavy for the bucket and had to be picked up at a point other than the center. About three swings of an eight pound hammer and the bent tooth is no longer bent. The teeth are probably no more than three inches long and I doubt that I would miss them if they weren't there.
Perhaps your dealer has had experience with another brand or has sold one to a customer who thinks that a compact tractor is a cross between a bulldozer and a battering ram.
</font><font color="blue" class="small">( I like the idea of the versatility of such a bucket, but my question is if you can get a 4 in 1 bucket that's as heavy duty as a heavy duty standard bucket? Strength and durability are important to me, and I wouldn't want to spend thousands of dollars on an attachment if its going to fail. )</font>
I agree with you about strength and durability but I'm not sure how to answer your question. I can only offer the experiences that I have had over the last four years of owning and using my 4in1 bucket. I have been able to accomplish a whole lot more than I could with a conventional bucket and my repair parts cost hasn't exceeded ten dollars. That meets my criteria for durable and strong. Your mileage may vary /forums/images/graemlins/smile.gif.
/ Four in One bucket recommendations #5
Gary,
Strange… I just left you a PM reply about this, but I’ll edit that reply to fit the questions here. /forums/images/graemlins/smile.gif
I have used crawler tractors and wheel loaders with 4n1 buckets. When I thought I needed one for my Kubota, I figured I would find a very strong bucket…
Really not that necessary, I do not think a tractor has either the horse power or traction to hurt any of the 4n1s that I have seen. You might look at WR Long, http://www.carverequipment.com/wrlong_loader_attachments.htm They look adequate for most 4n1 uses…
If you think you need a very heavy duty type, look at skid steer attachments. I bought a Thomas made in Canada. You do not have to spend a couple thousand to get a heavy duty 4n1. KennyV.
/ Four in One bucket recommendations #6
Gary,
Also keep in mind the extra weight of a 4in1 bucket over the standard bucket. A few years ago I looked very hard at a 4in1 bucket for my Kubota B21. As I remember it would have added almost 250 lbs which in my case is about a quarter of the loaders rated lift capacity. I just didn’t feel like I would be happy losing that much capacity the way I use my loader. There have been several members who have installed them on the same tractor as mine and been very happy so it all depends on your uses and capacity needs.
MarkV
/ Four in One bucket recommendations #7
</font><font color="blue" class="small">( <font color="blue"> Also keep in mind the extra weight of a 4in1 bucket over the standard bucket. A few years ago I looked very hard at a 4in1 bucket for my Kubota B21. As I remember it would have added almost 250 lbs </font> )</font>
I considered size and weight before I purchased my 4 in 1 and believe me...once I started using the 4 in 1 I NEVER looked back.
/ Four in One bucket recommendations #8
Roughcut, I sure don’t question how useful the 4-in1 is and often think how much it would help during some of my projects. If I up grade to a larger tractor in the future it is high on my list of options. I just wanted to point out that with as many benefits a 4-in-1 system offers there are some sacrifices in lift capacity.
MarkV
/ Four in One bucket recommendations #9
</font><font color="blue" class="small">( <font color="blue"> I just wanted to point out that with as many benefits a 4-in-1 system offers there are some sacrifices in lift capacity. </font> )</font>
In my use the weight is not an issue,because I use the 4 in 1 for some many other uses as grappling and grading,clearing brush. I do not think it is a weight issue as much as it is a volume issue and one that is very small. For all around use to me the pro's far outweigh the con's in the small sacrifice in volume. If a person was in a situation where day after day they were loading mulch/gravel etc and productivity was important I would say yes volume is an issue,but for the occasional gravel pile/manure pile and all the other things you can do with the 4 in 1,on a farm the 4 in 1 is far more beneficial than a standard bucket. I guess the key word is on a farm.
But I can see where a 4 in 1 would be a major asset to a land scape or construction/home builder.
/ Four in One bucket recommendations #10
Tony.
HI, it's me again. My 4in1 is about 150lbs more than the HD bucket so not much was given up. I have not noticed any time I could not lift a full bucket of anything to date. Not even close.
I did bent the front lower lip just a bit doing something stupid. Lifting a very large stump/root ball over the side of a 12yd dump truck. My guess is it was about 2200lbs and extending out about 3.5 ft beyond the jaw. I curled it up over the truck edge and into the box. The tremendous leverage caused a tweek. I straighted it out in 1 min. Never had that issue agian. Mine is an ATI and i have seen a couple that looked lkike they would be less likely to have that issue. I think one of them was a Woods and one was a Bradco. Check them out.
BTW, I was lucky to only pay 750 and my original bucket for my 4in1 when I purchased my L48. That seams like the time to get all you can in the deal.
Gray.
/ Four in One bucket recommendations #11
I plan to add a tooth on each bucket corner to improve the ability of the 4in1 to grab and hold logs such as the one in the picture. It is about 16inches at the but and 20ft long. It is from a ditch and is water logged to the point of being around 1600lbs in my estimate.
<font color="blue"> "Does your 4200 have the three position lockout on the DSCV? If you are going to use the DSCV to control the bucket, it's nice to be able to lock out the regenerative dump (middle position)." </font>
I have absolutely no idea how to answer that. Simply put, I really don't understand the question or know how to find out. Can you give me some idea how I might help you help me on this?
/ Four in One bucket recommendations #13
Gary in Indiana,
I think your post ended up in the wrong subject? You might give me a clue on my question? I am all ears.
I'll attach a veiw of the bucket for ideas.
/ Four in One bucket recommendations #14
Gary,
At the base of your joystick is a device to lock the joystick and make it inoperative. Early tractors, such as my 1998 4200 had a simple sliding lock pin. The joystick was either locked or unlocked. Sometime between 1998 and 2000, the lock was changed to a vertically travelling lever with three notches to secure it. When the lever is in the bottom position the joystick is locked. When it is in the middle position the joystick is unlocked but the regenerative function of curl circuit is locked out. When the lever is in the top position, the joystick is fully functional, including the regenerative function of the curl circuit.
Attached is an illustration from the on line manual showing the newer, three position locking control.
Selective Control Valve (SCV) lock lever (A) allows the operator to control the type of SCV lever movement needed for a particular operation or situation. Operation of the lock lever is indicated on label (B).
Move lock lever to the top position (C) to allow SCV lever movement in all directions. Operation of the SCV is totally unlocked.
Move lock lever to the middle position (D) to prohibit engagement of the REGEN (regeneration) function of the SCV. This position is recommended for all attachments except for the front loader. Loader operation may benefit from the use of the REGEN function. The REGEN position is available only with lock lever in position C.
Move lock lever to the bottom position (E) to prohibit SCV lever movement in all directions. Operation of the SCV is totally locked.
<font color="blue"> "I think your post ended up in the wrong subject? You might give me a clue on my question? I am all ears." </font>
Gray,
Actually, my post ended up exactly where I wanted it. /forums/images/graemlins/cool.gif
I think you may have missed the fact that I was responding to Jim Fisher, whose post I quoted in mine, and not to your post even though yours appeared immediately above mine. /forums/images/graemlins/smile.gif
Thanks for the pic of your bucket. It looks like a real nice setup and exactly what I'm hoping to add to mine. /forums/images/graemlins/cool.gif
/ Four in One bucket recommendations #16
Gary,
Off course, you are right- I missed what had happened.
I scanned back and saw the post.
I have one of the joy stick locks he is speaking of. Never have used it but may some day. It is a good safety device.
I may be posting more pictures now that I have it figured. They are as it is said- worth a 1000 words.
Jim,
I'm more than a little embarrassed to admit that I honestly don't know if I have that or not. It looks familiar but I don't know if I remember it from my tractor or from a picture like you posted. /forums/images/graemlins/confused.gif
I'm guessing my 4200 has it and, further, that I've never touched it or even thought about it. As I type this I can't help but remember all the times I was clearing brush and had a branch or vine start raising or tilting my bucket. Needless to say, those thoughts are punctuated by, "You mean I could have moved one darned lever and avoided all of that?" /forums/images/graemlins/blush.gif
All I can say is that I'm true to my gender; 'Directions? We don' need no steenking directions!' /forums/images/graemlins/wink.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
/ Four in One bucket recommendations #18
<ul type="square"> Move lock lever to the middle position (D) to prohibit engagement of the REGEN (regeneration) function of the SCV. This position is recommended for all attachments except for the front loader. Loader operation may benefit from the use of the REGEN function. The REGEN position is available only with lock lever in position C. [/list]
Would someone please explain the regen circuit, I know, I'm a bit slow but humor me please ???
/ Four in One bucket recommendations #19
Gary in Indiana.
I took a few pictures while clearing today. I have one of a stump grappled in the 4in1 before placing it on the burn pile.
/ Four in One bucket recommendations #20
Gary,
</font><font color="blue" class="small">( I'm guessing my 4200 has it and, further, that I've never touched it or even thought about it. )</font>
Nothing to be embarrassed about. You probably don't work without the loader very often.
The purpose of the lock (bottom position) is to prevent accidental movement of the joystick when the loader is removed. That way, you don't pressurize the circuits and have a hard time connecting the couplings when you install the loader. The middle position, which disables the regenerative function, should be used when you use the curl circuit (left and right stick) for something other than the curl cylinders - the 4in1 for instance.
You definitely have a lock of some sort. The question is which type. The early models only locked the stick and didn't disable the regenerative circuit. Not the best case scenario for controlling the 4in1 bucket with the joystick. Not saying that you can't - just that there are some limitations.
CRAFTSMAN ROLLING TOOLBOX (A62131)
CRAFTSMAN ROLLING...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
Yamaha Golf Cart (A64047)
Yamaha Golf Cart...
INOP/NON-RUNNING 2015 International DuraStar 4300 Lab/Chassis Truck, VIN # 3HAMMAAL3FL514548 (A61165)
INOP/NON-RUNNING...
207283 (A52708)
207283 (A52708)
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
