Found this today, what is it
/ Found this today, what is it #1
KenB2920
Veteran Member
Almont, Mi
Kubota L5240HSTC
Found this on the property today while using the metal detector .. Any idea what it is?
It's marked, patent pending MMI 4100
/ Found this today, what is it #2
From the picture it looks like a tubing or pipe bender. Are the top & bottom separated with a curved grove??
/ Found this today, what is it #4
Looks a lot like an EMT bending die, sort of like this one:
Bruce
/ Found this today, what is it #5
Need a side view next to a ruler. If it is big enough, could be a die for bending exhaust pipe or whatever.. Or maybe someone cast it just to mess with you...[[ :) ]] Quick uneducated search = MMI Engineering 4" radius die ....
LMAO!!! You guys rock.,, I'll look when I get home to see if it's grooved or if it's the angle of the photo.... But I see the bender for sure
/ Found this today, what is it #8
Now, if you can only find the rest of it...
/ Found this today, what is it #10
I don't thing it's a bender die, I thing it is for a cable to ride on.
After further review, clearly not a pipe bender
/ Found this today, what is it #17
1/2 of a crimping die .... [[ :) ]]
/ Found this today, what is it #18
To me it looks like part of what was once a bushing for a slow moving shaft on a farm implement. For example the shaft that raises the implement out of the ground. They were often made out of cast iron and held in place with a piece of steel on each side. That's what the shoulder on each side would be for.
/ Found this today, what is it #19
Appears to be cast aluminum, i'm guessing it's part of a pipe flange...
/ Found this today, what is it #20
Mike Tyson's mouthpiece??????
