Foton FT824 4wd
/ Foton FT824 4wd #1
ander26
Canada
Anyone have or know where to find some inside the cab pictures?
/ Foton FT824 4wd #2
If you can wait until monday I can get you some in cab pictures and depending on where you are in Canada you can come and take one for a test drive.
I will post some over the weekend.
I can tell you it's a much better cab than the FT40. The tractor overall is incredible for a chinese tractor. I can't say enough good things about the Fotons and especially the 82. Hopefully in a few months we will also be getting the 125hp in. Which is even BIGGER.
/ Foton FT824 4wd #3
Hi,
I think it was a Foton 82 I saw trucking on down the street the other day.
I was just amazed at how quiet it was when it went past me going the other way. Really looked like a nice machine.
Have a great nite
Tom
/ Foton FT824 4wd #4
Hey Mike,,
125 HP!!!!!!!!!
Can you post a picture of that Monster???
Move over Big Name Brands,, The Chinese Are Coming!!!!
Have a nice day,
Joe:cool:
/ Foton FT824 4wd #6
Here are the pics of the 125 and the 160. The biggest model they have is 182.
Currently they are only EPA certified up to 125. 125+ are available with dual rear wheels, etc...
125hp
165hp
ps, I didn't take these pics. But I hope to get a 125hp in by spring.
/ Foton FT824 4wd
Thanks for the pics and I was just wondering on the 824 how the 16x8 shuttle worked is there a third gearshift? and I also saw that you could assemble the tractor on your own and i would like to know if anyone knows what thet involves.
/ Foton FT824 4wd #8
The 824 we got was non shuttle.
As for assembly on them, I don't reccomend unless you have a full size shop and equipment. They ship on steel discs for the back wheels. You will need a large jack at the least. A wheel lift will aid in putting the tires on. The rest are simple things such as 3PH arms, weights, etc...
The big job is servicing the tractor. You have to drain all fluids, change all filters, etc... There are large amounts of fluids in this tractor and you will need something to drain them in.
There is also a matter of transporting the tractor. You will need a 10,000lb float trailer with ramps and chains to tie it down.
And finally, by having a dealer assemble your tractor they can catch any problems with the tractor you might not notice. This can save you future headaches.
/ Foton FT824 4wd #9
What I would really like to see in the larger tractors from Foton is a powershift transmission, the same as the ones in the Changlin/Foton loaders.
Once this is available they can truely compete with the big name machines.
/ Foton FT824 4wd #10
yes that would be a great addition.
/ Foton FT824 4wd #11
Hanging pedals
Side mount shifting
ample headroom with vents
Plenty of leg room
Extra windows for 3PH alignment
Remote and 3PH controls are much tighter than the 30/40 series cabs
A/C Controls
/ Foton FT824 4wd #12
crazy.....none of the pics open
/ Foton FT824 4wd
yea I cant get the pics to work either
/ Foton FT824 4wd #14
sorry guys, try this again
a/c controls
suspended foot pedals
new side mount gear shift controls
ample head room with sun roof
large spacious interior
rear side and bottom windows allow easy hookup to 3PH
Neat and tight remote and hitch controls. Far better than the 30/40 series.
/ Foton FT824 4wd #15
Thanks that's better!
2008 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2008 Dodge Ram...
ALUMINUM CUTTING BOARD, (2) POLY CUTTING BOARDS (A64278)
ALUMINUM CUTTING...
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
2025 8in Channel Tooth Bucket Mini Excavator Attachment (A64553)
2025 8in Channel...
1995 VOLVO A25C WATER TRUCK (A65053)
1995 VOLVO A25C...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
