Tiller forward or reverse tine tiller?
   / forward or reverse tine tiller? #1
scrapper
Pennsylvania
Kubota L 3400
I gonna get a new 60" tiller for my tractor. Which is better, foward directional tines or reverse? If it matters, my ground is somewhat rocky.
Thanks, Mike
   / forward or reverse tine tiller? #2
I gonna get a new 60" tiller for my tractor. Which is better, forward directional tines or reverse? If it matters, my ground is somewhat rocky.
Thanks, Mike
A question that has lots of discussion here.
I use a reverse rotation tiller and like it a lot. However, if you have rocky soil I suggest you go with a regular rotation machine. It will kick the rocks out the back instead of bind them up into the tiller. Either way, be sure it has a slip clutch instead of a sheer pin.
   / forward or reverse tine tiller? #3
IF the rocks are big enough to get jammed up in the tiller then I would also recommend a regular forward rotation one with slip clutch. Mine too is reverse rotation but not rocks around here to worry about. Get the slip clutch regardless.
:thumbsup:
Troy
Thanks guys, I have been looking at a Land Pride reverse and the King Kutter forward. About $900 difference in the price is also leaning me towards the forward, lol.
   / forward or reverse tine tiller? #5
I have yet to hear anyone bad mouth the KK tillers. MY only concern would be with service after the sale if something should break.
:thumbsup:
Troy
   / forward or reverse tine tiller? #6
My preference is for the reverse rotation also, but I don't have rocks to worry about so I think you have gotten really good advice.
   / forward or reverse tine tiller? #7
Heed the rock recommendations. I have lots of 6" plus sized rock on my land. They are always stalling the tiller. I like the one pass operations of the RT tiller but not the rocks.
   / forward or reverse tine tiller? #8
Reverse rotation is very effective because the tines aren't pushing the tractor before the soil is properly worked.
If you have large rocks just take a more shallow bite and when the tiller bounces over a big one just back up and use a spud bar to remove it safely to the FEL.
I'm afraid there's no getting around hand labor in removing the larger rocks...but doing that will pay dividends in the future.
   / forward or reverse tine tiller? #9
Savageactor7 is right on about the labor in tilling a field for the first time. I found several rocks to big to be lifted by hand that i had to dig out of the ground. After tilling a 7 acre field I had enough rocks piles up to start a quary.
   / forward or reverse tine tiller? #10
:) One option would be to purchase a tiller that the A-frame and gearbox assembly can be reversed for reverse rotation. I know several manufactures make them.
John Deere L125H Skidloader (RUNS) (A50774)
John Deere L125H...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
Ferris 52in Zero Turn Mower (A51694)
Ferris 52in Zero...
2013 Dodge Journey SUV (A50324)
2013 Dodge Journey...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
2012 Freightliner Cascadia 113 Semi (A50514)
2012 Freightliner...
