Forks for JD 460 FEL
   / Forks for JD 460 FEL #1
BillyP
Eagletown, OK
JD 4610 ehydro MFWD
Does anyone know what a set of forks would cost for a JD 460 FEL? Thanks
   / Forks for JD 460 FEL #2
<font color="blue">"...Does anyone know what a set of forks would cost for a JD 460 FEL?...</font>
Billy....
I paid $950 for the forks for my 460 FEL. See attachment.
....Bob
   / Forks for JD 460 FEL #3
Another closer view of the forks...
   / Forks for JD 460 FEL #4
List price on mine was $1020 at the time. I paid $810.
   / Forks for JD 460 FEL #5
Cowboy Doc,
How much can you actually lift with those forks? I'll need to lift 3000lb pallets of stone - and I fear that is too much for the 460 - mounted on a 4710.
Bill
   / Forks for JD 460 FEL #6
I doubt that you can lift more than 1,000 lbs of stone on a pallet with forks on the 460 FEL. The manual reccommends no more than a 700 lb hay bale with a hay spear so the limit with the forks will be similar.
   / Forks for JD 460 FEL #7
I lift 2000 lb. bales with mine. I lift them up and into round bale feeders. I've done thousands with it and no problems.
   / Forks for JD 460 FEL #8
<font color="blue">"How much can you actually lift with those forks? I'll need to lift 3000lb pallets of stone - and I fear that is too much for the 460 - mounted on a 4710."</font>
Dealer told me these forks are rated at 1,800lbs lift capacity. However, he also mentioned customers he has had have lifted 2,000-3,000lbs. Lifting 3,000lb+ consistently may be pushing it a bit.
   / Forks for JD 460 FEL #9
I regularly lift ~ 2000lb pallets with mine. I can't belive how useful these are.
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
2008 Cadillac Escalade ESV 4x4 SUV (A51694)
2008 Cadillac...
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
2023 LMC M40018 LOT NUMBER 72 (A53084)
2023 LMC M40018...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
