Forks Again
/ Forks Again #1
bkennedy
Ontario, Canada
JD 2520
I know the forks question has been covered many times here. I am trying to decide between Horst light 44" forks (230 lbs) and Horst regular duty 48" forks (300lbs) to go on a 2520. Any suggestions?
Also has anyone bought or created a boom type attachment for the forks to carry or lift something very light but bulky?
/ Forks Again #2
Hiya,
I have the light duty Horst for my 2520. They will work just fine with anything the loader will pickup. Plus since they weigh 70 Lbs less than the regular duty, that's more material you can lift.
Tom
/ Forks Again #3
get the short tines on the forks. not the 48.
i have frontier 42 in tine fixed rail forks on my 2520 and thay work great.
you dont need 48 inch tines on a fork for a tractor this size. its just more weight.
Chris.....:)
/ Forks Again #4
I have the 42" Frontier fixed tine forks on my 2520. I agree with the above posts, get the 42. The more the forks weigh, the less you can pick up.
Regarding the lifting attachment, I haven't gotten around to it yet, but I'm going to make one from a piece of 6" channel iron, about 3 feet long that will lay across the forks and be clamped on. It will have a 2" receiver hitch tube welded right in the middle and some chain hooks welded to each end. Got the parts sitting on my workbench, just ain't had the time...
/ Forks Again #5
48 vice 42-----depends on what your lifting requirements are. I routinely lift things with steel/alum structure that are 3 to 4 feet wide. (docks, snowmobiles, frames). Having forks that span the structure and support both sides of the frame is handy. Also find great utility in longer tines when moving bulky lighter stuff such as brush piles. So which is best for you probably depends on what you intend to lift. Good luck.
/ Forks Again #6
in that case , there are companies that make extentions up to 60 inches.
so get the 42 for max lift. and if you need reach. just slip the extentions on.
Chris....:)
/ Forks Again #7
Agree that extensions are a good option for large bulk/low weight stuff. But you do pay a weight penalty by doubling up the existing tine structure.
The only time I wish I壇 gone the 3320 route is when I max out FEL capacity. Not a big deal with aggregates/dirt, but its hard to lift a metal lathe in two passes?..
1992 GMC Top Kick Fuel Truck (A62679)
1992 GMC Top Kick...
2017 Case CX145D (A62177)
2017 Case CX145D...
Bush Hog 13414 (A64126)
Bush Hog 13414...
(1) 30 Yard Roll Off Dumpster and (1) 20 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
