Fork lift quick attatch
   / Fork lift quick attatch #21
i duno i may be wrong but sounds like by the time you pay for the QA modification so you can use other skid steer QA stuff you have spent more money than buying the Bota Stuff that their QA is made to work with
i really only want pallet forks and a post hole digger but i can make a plate to mount the PHD to.
uggg i just need to sell my bx so I can move on
thanks for the info guys
   / Fork lift quick attatch #22
Once you have the universal QA - you will find other toys to hook up to it. One of my favorites for moving stuff:
Bob Cat Attachments
The only real issue is that the weight restrictions of the B3030 will drastically limit the usefulness of skid steer equipment. The only advantage of going with the Kubota forks is that they are likely sized to the capacity of the tractor. For a small tractor, a 200 pound set of forks with 2000 pound capacity will outperform a 400 pound set with a 4000 pound capacity. Although you can find the lighter duty skid steer forks, because few carry them they tend to be about 1 1/2 to 2 times the cost of the heavier duty forks (probably on par with the cost of the Kubota forks).
If the cost is a wash, I would seriously consider the universal QA.
My two cents.
Joe
Thanks for the help guys, I found a used set from a CAT dealer for $700OTD. They are like brand new.
Alex
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2004 CAT 953C Crawler Loader (A47477)
2004 CAT 953C...
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2018 FORD TRANSIT T150 CARGO VAN (A54313)
2018 FORD TRANSIT...
