Fork lift Frame
/ Fork lift Frame #1
Dale1995
Caribou,Maine
John Deere 2320
I am in the process of building a set of forks for my 2320 John deere tractor, I just purchased a set of 1000 lb capacity forks from a supplier, since my tractors lifting capacity is only 989 lbs, I figured that the forks would be plenty strong. My question is I am going to build this fork lift frame out of 2" x 4" rectangular tubing, in order to keep the weight down I am planing to use 3/16 " wall thickness, instead of 1/4" thickness. Tubing is very strong, has any one out there done this and what is your opinion? Will this be strong enough for my needs? Thanks for any help.:)
/ Fork lift Frame #4
-what did the forks cost you?
I paid $100US for my used 42" forks from a forklift dealer. They where "out of spec" for real forklift use but still have plenty life in them for a CUT.
/ Fork lift Frame #5
I don't know if this is what you are looking for. I used 2''x4'' 3/16'' for the top and bottom. 3/8''x 4'' for the sides, and 6'' x 1/4'' channel for the loader mount. 1 3/4'' round for the forks, that are old brick forks.
PORTA POTTY (A68842)
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
2019 ALLMAND LIGHT PLANT (A67714)
2019 ALLMAND LIGHT...
2015 Ford F-250 4x4 Crew Cab Pickup Truck (A66736)
2015 Ford F-250...
Engine knock
Engine knock
20' CONNEX BOX (A67714)
20' CONNEX BOX...
