Forks Fork level Indicator
   / Fork level Indicator #11
All of the above is good advice but remember as you raise your bucket you need to curle down to keep it level!
:welcome: to TBN! :thumbsup:
Happy :tractor: ing!
   / Fork level Indicator #12
I just watch framework of the forks to keep mine level.
   / Fork level Indicator #14
Just attach a couple of feet of vertical pole to the pallet attachment. Something you can see from the seat. A bit of old fishing rod would do the trick. As long as the rod is vertical then the pallet is level.
Maybe you are over-concerned about this. I've unloaded plenty of stuff and its not hard to keep things reasonably level.
I've always found the hardest thing is to get the forks under a pallet on rough ground.
   / Fork level Indicator #15
The geometry of a tractor loader is not conducive to lifting and lowering level as you have to work the curl/dump along with lift/lower. Skid Steers seem much better at this, but they lift in a very different manner. There are variations on that, of course.
But if your main task for the machine is unloading pallets, then I would argue that a tractor is not the best tool for the job. You would be better off with a SS that has level-lifting geometry or finding a smaller used forklift. My 2 cents...
Apache,
What you are looking for can be found here:
Boom Angle Indicators | Tilt Meter | The R&B Manufacturing, Inc.
They are a bit light duty, but they work.
Thanks, this will work!
the main thing I want is for the forks to be level at tractor trailer floor/bed level, 1, so I don't damage the product by poking up through the pallet and scratching or piercing it, and 2, not to stab down through the pallet and damaging the floor/bed of the truck, I have seen this done both ways with a "Real" forklift and the affected party was not happy.
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
2012 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTN6 LIGHT TOWER (A55745)
2012 WACKER NEUSON...
2019 Dodge Grand Caravan SXT Van (A55853)
2019 Dodge Grand...
2014 MACK CHU613 DAYCAB (A55745)
2014 MACK CHU613...
2016 Ford Explorer...
