Forgot and left the block heater plugged ino
   / Forgot and left the block heater plugged ino #22
I worry about attracting rodents with the heat. Reasonable concern or not?
Seems like it would be, especially if plugged in 24/7.
Once you plug in and and have a heat source, then yes wind chill stripping that heat away is real. I'm curious if, or why, vehicles experience it otherwise.
I did the opposite test of the OP last week, when I thought I'd plugged the tractor in, it looked like I did. but the picture shows what I discovered.
Oops, must of did that when I was pulling the other end of the cord to the tractor.
I wondered why it started so hard! Turns out, you have to plug it in ALL the way! image-1700937566.jpg
   / Forgot and left the block heater plugged ino #23
That tine is begging to catch a spark?
   / Forgot and left the block heater plugged ino #25
Yes it will. Cats also.
Yes, cats also. I used to keep the dump truck in my avatar plugged in 24/7 when on call for hauling snow. The heater was a humungous thing on the oil cooler of the Cat 3406B engine which was just the right size for a kitty cat to snuggle up on top of. Many times that's just what happened, so I always checked before starting to make sure there weren't two Cats under the hood. :D
   / Forgot and left the block heater plugged ino #26
If wind chill is not a factor why put a piece of cardboard in front of the radiator for cold weather? Just asking.
Edit: Okay, I guess the restriction of ANY air is going to warm up the coolant system faster.
   / Forgot and left the block heater plugged ino #27
I leave my Kioti plugged in all the time.
   / Forgot and left the block heater plugged ino #28
Life safety generators, emergency fire pumps, and the like have block heaters on 24/7/365. Many of them do use thermostats, but they are not allowed to cool off completely unless taken out of service.
My 97 Dodge Cummins gets plugged in about October, and unplugged about April. Mostly because the beast has a huge cooling system, and if I'm not driving for an hour, I ain't getting any heat! I also block off the air flow at the grill.
You most certainly will not harm one by leaving it plugged up, but I have always contended that you can 'spoil' one by plugging them in, meaning they will start cold, but will whine like your teenager when you get them up for school on a cold morning!
George
   / Forgot and left the block heater plugged ino #29
The cardboard was quite common at one time. Also switching thermostats winter and summer was done.
   / Forgot and left the block heater plugged ino #30
Wind chill won't make anything colder than the ambient temperature. Once you have a heat source though, cold wind will strip the existing heat away (cooling the mass to to ambient temperature) faster. At least that's how it works in my mind. I could be wrong.
   / Forgot and left the block heater plugged ino #31
The only thing the OP hurt was his electric bill!
That would've been ~$10 on my bill.
ac
   / Forgot and left the block heater plugged ino #32
Just purchased a countdown timer from Amazon and installed same on the power cable to my block heater. You can set the time for one, two or more hours. Looks like it will get used tomorrow morning! Now the following morning and the switch works great! At my age I might forget and leave heater plugged in but this count down switch solves that issue.
   / Forgot and left the block heater plugged ino #33
The block heaters have a built in thermostat.
So do the in-line radiator hose units. (At least the ones I used years ago.)
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
12' CONTAINER (A52706)
Leyman Lift Gate (A59230)
Leyman Lift Gate...
UNUSED RAYTREE REDM32 HYD MULCHER (A60432)
UNUSED RAYTREE...
1985 Ford Ltl9000 Tender Truck (A61307)
1985 Ford Ltl9000...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
